Can we setup filter in order to see debug ip packet clearly without BGP message in BGP router?
wfqk
Level 5
Level 5
Hi In router configured with ospf, if we set up debug ip packet, we will see a lot ospf multicast message, which interferes with what we want to see. So if we want to see debug ip packet clearly, we can set up acl to filter ospf multicast message. In BGP router, can we have similar way to do that? Thank you
5 Replies 5
Philip D'Ath
You really don't want to be using "debug ip packet" unless you are desperate.  On anything other than a lightly loaded router it can cause the router to crash.
Have you tried:
debug ip ospf packet
debug ip bgp all
Hello
You can negate unwarranted logs by using an ACL and a debug condition on a specific interface
access-list 100 permit ospf any any
or
access-list 100 permit top any any eq bgp
debug condition interface x/x
debug ip packet detail 100
res
Paul
Kind Regards
Paul
Hi Paul, Thank you for your reply. The below is my configuration for it, but it looks look that the config cannot block bgp message. Do you think something is wrong. thanks
R4#sh debug
Generic IP:
IP packet debugging is on (detailed) for access list 100
Condition 1: interface Et1/0 (1 flags triggered)
Flags: Et1/0
R4#sh ip access
Extended IP access list 100
20 deny tcp any any eq bgp (54 matches)
40 permit ip any any (84 matches)
Hello
thats because your acl is stating to block bgp and then allow everything -it an incorrect statement
Also you don't really need deny traffic as by default there is an implicit deny to ACL's
So use one of the ACL examples I posted and you should be fine
res
paul
Kind Regards
Paul
After I changed to the following, debug message still can be seen. Is it possible for us to not see any bgp debug message if using debug ip packet? thanks
R4(config-ext-nacl)#do sh debug
Generic IP:
Flags: Et1/0
R4(config-ext-nacl)#do sh ip access
10 permit tcp any any eq bgp (28 matches)
