Configuring WIC-1T, HWIC-1T in the CISCO2801, 2811
Soon Kwan Kwon
Hello everyone.
I have 2 issues.
One is about WIC-1T
Another is about HWIC-1T
The point I make a question is about "supporting"
[ WIC-1T ]
I searched WIC-1T datasheet ( http://www.cisco.com/c/en/us/support/docs/interfaces-modules/1700-2600-3600-3700-1-port-serial-wan-interface-card/7265-hw-1t-wic.html )
But there isn't indicated that CISCO2801 does support WIC-1T.
Is it right?..
I have a experience that I connected it to CISCO2801, 2811...
[ HWIC-1T ]
I have 2 HWIC-1T modules.
When I connect it CISCO2801 and 2811, the LED on the router does not shine and no response...
Seeing the datasheet, you can obviously see It is supporting it. ( http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/high-speed-wan-interface-cards/datasheet_c78-491363.html )
Maybe I think HWIC-1T I have is broken down..?
(But 1941 Router recognize HWIC-1T - I'll prove through "show inventory" command)
Thank you for reading.
acampbell
The 2800 series routers do NOT support WIC-1T it needs to be an HWIC-1T.
See this table
http://www.cisco.com/c/en/us/products/routers/2800-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html#serialwan
Regarding the 2800s not seeing the card:-
Make sure you meet the minimum IOS & feature levels
IOS Release, Feature Sets, Licenses and Platform Support
Table 2. Minimum IOS Releases, Feature Sets and Licenses
Platforms
Minimum Cisco IOS Sotware Release
Minimum Cisco IOS Sotware Feature Set or License
Cisco 1800, 2800, and 3800 Series Integrated Services Routers
• 12.4(20T
• 12.4(23)
• 12.4(15)T
IP Base
Cisco 1900, 2900, and 3900 Series Integrated Services Routers
• 15.0(1)M
IP Base
Make sure you power down the router, install the card the re-power the router.
2800s do NOT support OIR (Hot card installation)
Alex
Regards, Alex. Please rate useful posts.
acampbell
See this table
Platforms
• 12.4(20T
• 12.4(23)
• 12.4(15)T
IP Base
• 15.0(1)M
IP Base
Alex
Chin Hoong Yap
According to http://www.cisco.com/c/en/us/products/routers/2800-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html#end, the WIC-1T is an End-of-Sales (EOS) module that is supported on the 2800 Series Integrated Services Routers.
Below shows a Cisco 2811 router running Cisco IOS 15.1(4)M10 is able to recognize a WIC-1T installed on it.
Thanks. :-)
Router#show version
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 15.1(4)M10, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Tue 24-Mar-15 09:00 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
Router uptime is 4 minutes
System returned to ROM by reload at 09:21:19 UTC Wed Mar 30 2016
System image file is "flash:c2800nm-adventerprisek9-mz.151-4.M10.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 1.0) with 512000K/12288K bytes of memory.
Processor board ID FHK1404F3RF
2 FastEthernet interfaces
1 Serial(sync/async) interface
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
191K bytes of non-volatile configuration memory.
126976K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2811             FHK1404F3RF
Router#
Router#show inventory
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811         , VID: V07 , SN: FHK1404F3RF
NAME: "WAN Interface Card - Serial (1T) on Slot 0 SubSlot 0", DESCR: "WAN Interf
ace Card - Serial (1T)"
PID: WIC-1T=           , VID: 1.0, SN: 20459184
Router#
Router#show diag
Slot 0:
        C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports
        Port adapter is analyzed
        Port adapter insertion time 00:04:07 ago
        Onboard VPN             : v2.3.3
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC14010TP4
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-26920-05
        Board Revision           : A0
        Deviation Number         : 0
        Fab Version              : 04
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 87
        Hardware date code       : 20100104
        Chassis Serial Number    : FHK1404F3RF
        Chassis MAC Address      : 9caf.cab3.0530
        MAC Address block size   : 24
        CLEI Code                : COMWL10CRA
        Product (FRU) Number     : CISCO2811
        Part Number              : 73-10258-06
        Version Identifier       : V07
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 34 30 31 30 54 50 34 40
          0x10: 03 E7 41 01 00 C0 46 03 20 00 69 28 05 42 41 30
          0x20: 88 00 00 00 00 02 04 03 00 81 00 00 00 00 04 00
          0x30: 09 87 83 01 32 B4 08 C2 8B 46 48 4B 31 34 30 34
          0x40: 46 33 52 46 C3 06 9C AF CA B3 05 30 43 00 18 C6
          0x50: 8A 43 4F 4D 57 4C 31 30 43 52 41 CB 8F 43 49 53
          0x60: 43 4F 32 38 31 31 20 20 20 20 20 20 82 49 28 12
          0x70: 06 89 56 30 37 20 D9 03 40 C1 C2 FF FF FF FF FF
        WIC Slot 0:
        Serial 1T WAN daughter card
        Hardware revision 1.0           Board revision J0
        Serial number     20459184      Part number    800-01514-01
        FRU Part Number     WIC-1T=
        Test history      0x0           RMA number     00-00-00
        Connector type    Wan Module
        EEPROM format version 1
          0x20: 01 02 01 00 01 38 2E B0 50 05 EA 01 00 00 00 00
          0x30: 98 00 00 00 00 05 30 01 FF FF FF FF FF FF FF FF
Router#
