Showing results forĀ
Search instead forĀ
Did you mean:Ā
Can we VTP prune native VLAN?(Not VLAN 1)
veerendrav2
As we know VLAN 1 is by default "native". All control traffic(CDP, LLDP, STP BPDUs, etc) uses this native VLAN 1 and it is not eligible for  VTP pruning
1. What if I set VLAN 10 as "native"? then CPD, LLDP, BPDUs uses this VLAN 10 for their communication?
2. If I set VLAN 10 as "native", now can I VTP prune that VLAN 10?
3. Can I do "switchport trunk allowed vlan all except 1": VLAN 1 "except"? In the same way, can I do manual pruning for VLAN 10 which native VLAN?
4. How point 2 and 3 effect CPD, LLDP, BPDUs i.e if I prune, how protocols exchange data (LLDP, CPD, BPDUs)
Jon Marshall
1) No, they continue to use vlan 1 except now they are tagged. This applies to all control protocols with the exception of DTP which follows the native vlan ie. it is always untagged.
2) As far as I know yes providing you are not using the native vlan for any end devices etc.
3)  You can prune vlan 1 but it will still be used for the control protocols.
4) see 3)
Jon
Jon Marshall
4) see 3)
Jon
