can WS-X6748-GE-TX support interface MTU command ?
boonteongng
This is a WS-X6748-GE-TX in a 7609 with sup720. The mtu command is not found under the interface configuration. Can this module support interface mtu configuration ? or is there any other pre-configurattion required for the module to support interface MTU ?
wdrootz
Level 4
Level 4
You are hitting the bug - CSCef94635
