Cannot access 1131ag access point from 1801 Router
shaw.chris
I wish to extend Wireless access in our office and have a AP1131AG access point connected to a 1801 Router on port FastEthernet2,
The 1801 has several VLANs configured, Public Internet access is on VLAN7.
The access point is still on the default Native Vlan 1 and I have assigned it IP address 192.168.10.2
The clients connect to the access point but cannot receive DHCP from the 1801, I also cannot ping/ssh to 192.168.10.2 from the 1801.
Here is a snippet from the 1801 config, can anyone point me in the right direction as to what could be wrong..........
Chris
dot11 ssid Wireless
   vlan 7
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 xxxxxxxxxxxxxxxxxxxxxx
vlan 7
bridge irb
interface FastEthernet2
switchport access vlan 7
interface Dot11Radio0
no ip address
no ip route-cache cef
no ip route-cache
encryption vlan 7 mode ciphers aes-ccm
ssid Wireless
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.7
encapsulation dot1Q 7 native
ip virtual-reassembly
no ip route-cache
timeout absolute 120 0
no cdp enable
bridge-group 7
bridge-group 7 subscriber-loop-control
bridge-group 7 spanning-disabled
bridge-group 7 block-unknown-source
no bridge-group 7 source-learning
no bridge-group 7 unicast-flooding
interface Vlan7
no ip address
bridge-group 7
interface BVI7
ip address 192.168.10.1 255.255.255.0
ip nat inside
9 Replies 9
Out of which physical interface on the 1811 do you have the AP connected to?
Do you see the AP on the ''sh cdp neigh'' on the router?
Do you see the AP on the ARP table?
Federico.
The device is not showing up on the arp table, the WAP is connected to the 1801 port FastEthernet2
I'll take a look at cdp neighbours when I'm back in the office in the morning...
I'm sure this is some sort of VLAN issue as I connected it to a 877W (which only had the default vlan1 configured) and it extended the Wireless signal successfully and picked up dhcp from the 877W
Chris
Leo Laohoo
Your configuration snippet doesn't make sense.  You have a router, 1800.  Your configuration shows BOTH the router (you have Fastethernet 2) and the AP (BVI, SSID and Wireless).
Can you please post BOTH separately?
Hi, sorry the device is a 1801W so has integrated wireless, so the config is correct
I can confirm I can see the AP using cdp neighbors from the 1801W
Below is a snippet of the config from the AP1131AG
dot11 ssid Wireless
authentication open
guest-mode
bridge irb
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid Wireless
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
no dfs band block
channel dfs
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.10.2 255.255.255.0
no ip route-cache
bridge 1 route ip
The 1801's Fa2 is connected to the AP.
You see the neighbor using CDP
But you cannot PING?
You're saying the 1801 has 192.168.10.1 and the AP 192.168.10.2
Can you confirm that information doing a ''sh cdp neigh det''
And see if you can PING then?
Federico.
Hi Federico,
Yes the AP is connected to the 1801W's Fa2 port
"sh cdp neighbours detail" shows the AP and the correct IP address (192.168.10.2)
When I try to ping 192.168.10.2 from the 1801W it doesn't work, also clients connected to the AP cannot pick up a DHCP address from the 1801W
Chris
Can you confirm the correct interfaces by posting the output of the ''sh cdp neigh det'' here?
Is there an ACL applied to the Fa2 interface on the 1801?
Federico.
Marko Leopold
Hello Chris!
Maybe you can look at this configuration example.
http://www.cisco.com/en/US/partner/tech/tk722/tk809/technologies_configuration_example09186a0080665ceb.shtml
Greetings,
Marko
Thanks for the link, the AP has suddenly kicked into life so seems like the config was ok after all.
