Need Clarification: Do I Need An IOS Upgrade?
frivers
XXX_OPS#show ver
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(15)T12, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 22-Jan-10 02:04 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
ABT_OPS uptime is 2 days, 58 minutes
System restarted at 15:11:28 PCTime Tue Apr 13 2010
System image file is "flash:c2800nm-ipbase-mz.124-15.T12.bin"
Cisco 2821 (revision 53.51) with 514048K/10240K bytes of memory.
Processor board ID FTX1413AJTF
2 Gigabit Ethernet interfaces
1 Serial interface
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
126976K bytes of ATA CompactFlash (Read/Write)
ABT_OPS#
I want to do dot1q tagging and vlan trunking on this router.  Is it possible?
10 Replies 10
paolo bevilacqua
Yes.
Why does the Cisco Feature Navigator say my model can do it?
Jon Marshall
Frank
According to Feature Navigator IP Base on the 2800 ISR routers should support 802.1q trunking so you should be fine. If you want to make sure then try this -
int gi0/1.10
encapsulation dot1q 10
ip address x.x.x.x
if you can enter the above config you are good to go.
Feature Navigator is the tool to use for these sort of queries -
Feature Navigator
Jon
It doesn't work.
What exactly doesn't work ?
Jon
Unrecognized command.
frivers@myatlanticbank.com
Frank
We can help you if you help us. Which bit is an unrecognized command ie. when you try and create the subinterface, when you try and add the encapsulation etc..
Jon
it works, sorry.
it works, sorry.
Frank
No problem, we all have those sort of days
Glad you got it working.
Jon
here is the screen shot from feature navigator
Software
Major Release
Release
Platform
Feature Set/License(s)
New Search
Search Results
Cisco IOS quick pick latest Releases
GD Release
LD Release12.4(13)  12.4(4)T3
ED Release15.1(1)XB  15.0(1)M2  12.4(24)T3  12.4(11)XJ4  12.4(6)XT2  12.4(6)XE3  12.4(4)XC7
12.4(2)XA2  12.3(14)T7  12.3(11)YZ2  12.3(11)XL1  12.3(8)ZA
MD Release12.4(25c)  12.4(15)T12
You could open a tac case, as even on IPbase this is supposed to work.
Might as well plan an upgrade.
