Cannot access router due to router Natting SSH return connection
carl_townshend
Hi All
We have had some issues whereby we cannot ssh to a router when we have PAT enabled.
I can see the router is trying to NAT the return connection back and so doesn't work.
The fix was to deny NAT from the routers public IP back to me.
Any ideas why this is happening?
Many thanks
Giuseppe Larosa
Hello Carl,
without seeing your PAT configuration including involved ACLs is difficult to say something meaningful.
Also it would help to know the model of router and the IOS image running on it.
So also a show version would be nice to have.
In theory NAT operation is triggered going through a nat inside to a nat outside interface.
Hope to help
Giuseppe
ip access-list extended NAT
deny ip 172.20.X.X 0.0.255.255 172.16.0.0 0.X.255.255
remark NO NAT RULE AND NAT FOR INTERNET
deny ip host 125.X.X.X any
permit ip any any
int gig 0/0/1
ip nat inside
int gig 0/0/0
ip nat outside
ip nat inside source list NAT interface GigabitEthernet0/0/0 overload
Cisco IOS XE Software, Version 16.06.03
ISR4331/K9
Hello Carl,
using an ACL statement with permit ip any any is not recommended
You know your internal network (s) that line should be something like
permit ip 172.20.0.0 0.0.255.255 any
This way you wouldn't need the specific line before
Hope to help
Giuseppe
