Cannot access website from LAN
Allihopp
Hi everyone.
My organization has a ESXi server with virtual machines, and on one of them there are docker containers, inside one of those containers is a website.
Yesterday everything was working fine, but today, when we moved the server to Cisco (891f router) network, the website is not acessible from LAN, even though from WAN everything works finetw, pinging the domain name responds with local IP, if that's important.
What could cause such a thing?
16 Replies 16
balaji.bandi
This need clarity, where was the server before ? - I may suspect any ACL ?
is the only web service not working in LAN IP ?
can you give example IP of Lan and webserver IP ?
can you able to ping from LAN to web Server ?
BB
Currently, this is the only server, that is not working properly, it's IP is 192.168.0.191.
Btw, 192.168.0.200 works perfectly, either on LAN or over WAN.
ip dhcp excluded-address 192.168.0.0 192.168.0.100
ip dhcp excluded-address 192.168.0.190 192.168.0.254
ip dhcp pool dhcp_pool_1
 network 192.168.0.0 255.255.255.0
 default-router 192.168.0.1
 dns-server 1.1.1.1 8.8.4.4
 lease 3
interface GigabitEthernet8
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface Vlan1
 ip address 192.168.0.1 255.255.255.0
 ip nat inside
ip nat inside source list 100 interface GigabitEthernet8 overload
ip nat inside source static tcp 192.168.0.200 3389 x.x.x.x 19500 extendable
ip nat inside source static tcp 192.168.0.200 80 x.x.x.x 19580 extendable
ip nat inside source static tcp 192.168.0.200 19596 x.x.x.x 19596 extendable
ip nat inside source static 192.168.0.191 x.x.x.x
access-list 100 permit ip 192.0.0.0 0.255.255.255 any
Also, I cannot remove this part (to manually add ports, as with the 192.168.0.200 server)
because it gives me an error:
Static entry in use, do you want to delete child entries? [no]: yes
%: Error: static entry still in use, cannot remove
Even though I cleared NAT translations.
 dns-server 1.1.1.1
 lease 3
interface GigabitEthernet0
 no ip address
interface GigabitEthernet1
 no ip address
interface GigabitEthernet2
 no ip address
interface GigabitEthernet3
 no ip address
interface GigabitEthernet4
 no ip address
interface GigabitEthernet5
 no ip address
interface GigabitEthernet6
 no ip address
interface GigabitEthernet7
 no ip address
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
interface Vlan1
 ip nat inside
ip nat inside source static tcp 192.168.0.191 80 x.x.x.x 80 extendable
ip nat inside source static tcp 192.168.0.191 45201 x.x.x.x 45201 extendable
ip nat inside source static tcp 192.168.0.191 45202 x.x.x.x 45202 extendable
ip nat inside source static tcp 192.168.0.191 45203 x.x.x.x 45203 extendable
On the first server (192.168.0.191) there's installed Docker, with a container, that serves a website on a domain www.domain.com (example). Before moving that server to a Cisco network, the server also was on a 192.168.0.0/24 network, and the website was accessible by domain on both LAN and WAN. Now only by domain from WAN, from LAN it's impossible to access it even by internal ip:port.
On the other hand, the second server works fine from the global internet, accessing by public IP and port, and from LAN by local IP and port.
it would be useful to have a schematic drawing of your topology, showing where exactly the webserver is located. You have a static NAT entry for the webserver, when your LAN clients access the webserver, do you see any NAT entries (show ip nat) ?
Also, is this the full configuration ? I do not see any routing...make sure you have a default route:
--> ip route 0.0.0.0 0.0.0.0 GigabitEthernet8
Adding ip route to gig8 (WAN interface) doesn't help.
What do you mean by schematic drawing?
with schematic drawing I mean a visual layout of your topology.
What NAT entries do you see when you (successfully) access the webserver externally ?
i do not see any route out.
either you try below :
ip route 0.0.0.0 0.0.0.0 dhcp
or
ip route 0.0.0.0 0.0.0.0  gig 8
post also
show IP route
show nat translation
BB
or
Nothing helped, during the day. Will post the log from commands tomorrow.
I was reading your comments again. So from outside with FQDN your website working ok, Internally from same subnet you not able to access same site using IP and port number, what is the message you getting when you type  HTTP://ip (with port)
what is the Lan IP address you trying to access to web server ?
i also suspect this ACL wrong :
no access-list 100 permit ip 192.0.0.0 0.255.255.255 any
access-list 100 permit ip 192.168.0 0.255.255.255 any
BB
Hello
you need to apply a specific pat  statement for the .191 just like you show for .200
ip route inside static 192.168.0.191 <port> x.x.x.x <port>
suggest also to append deny ace entry’s in your nat access-list  for the static pat addresses
no access-list 100
access-list 100 deny ip host 192.168.0.200 any
access-list 100 deny ip host 192.168.0.191 any
access-list 100 permit ip 192.168.0.0 0.0.0.255
ip route 0.0.0.0 0.0.0.0 GigabitEthernet8 dhcp
lastly to delte an existing pat statement suggest to temporarily disable the lan interface so the rtr isnt trying to use perform nat on the statement whilst you remove it
Kind Regards
Paul
Can you explain why, please?
Allihopp
@paul driver @Georg Pauwen @balaji.bandi
Look, I've tried to show my current network:Network_smaller.png
Everything was working as I need on our previous router Netis WF2780 (yeah, not the best solution for an organization, but that's not my fault), with the same exposed ports. Literally, just changed the router to Cisco 891F.
After some of your suggestions above, the Website on Docker container is accessible by IP : port, but I need it to be accessible by our public domain.
Here is the full configuration of Cisco router:
Building configuration...
Current configuration : 2958 bytes
version 15.3
hostname Router_1
boot-start-marker
boot-end-marker
aqm-register-fnf
aaa new-model
aaa authentication login default local-case
aaa session-id common
clock timezone EEST 2 0
 lease 3
ip name-server 1.1.1.1
ip name-server 8.8.4.4
ip cef
no ipv6 cef
license udi pid C891F-K9 sn FCZ2043E05T
username blackhawk privilege 15 secret 5 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
ip ssh version 2
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 isdn termination multidrop
interface FastEthernet0
 no ip address
 shutdown
 duplex auto
 speed auto
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
interface Vlan1
 ip nat inside
interface Async3
 no ip address
 encapsulation slip
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source static tcp 192.168.0.200 3389 X.X.X.X 19500 extendable
ip nat inside source static tcp 192.168.0.200 80 X.X.X.X 19580 extendable
ip nat inside source static tcp 192.168.0.200 19596 X.X.X.X 19596 extendable
ip nat inside source static tcp 192.168.0.191 80 X.X.X.X 80 extendable
ip nat inside source static tcp 192.168.0.191 45201 X.X.X.X 45201 extendable
ip nat inside source static tcp 192.168.0.191 45202 X.X.X.X 45202 extendable
ip nat inside source static tcp 192.168.0.191 45203 X.X.X.X 45203 extendable
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 no modem enable
line aux 0
line 3
 modem InOut
 speed 115200
 flowcontrol hardware
line vty 0 4
 transport input all
scheduler allocate 20000 1000
end
Hello
Do you mean you would like to access this website internally via its public natted ip address or externally the website isn’t reachable?
Kind Regards
Paul
@paul driver wrote:
Hello
I need to make it accessible by public domain, even from LAN.
Currently figured out, that adding to users PCs hosts file following line makes it possible to access:
192.168.0.191	www.domain.com
But it's stupid manually adding this to each of 50 computers.
