Cannot block access to youtube
Abdullah Net
Hello there,
I have been trying for a while to block access to both youtube.com and torrent connections. Lately, i have been successful with blocking torrent connections but blocking youtube does not seem to work although i have the right commands.
My config
hostname Internet_Router
boot-start-marker
boot-end-marker
enable secret 5 $1$/nHD$yvyxg0xJcN2NDAmArp1yK1
no aaa new-model
ip name-server 62.215.6.51
class-map match-all torrent
match protocol bittorrent
class-map match-any youtube
match protocol http host "*youtube.com*"
match protocol http host "www.youtube.com"
match protocol http host "youtube"
match protocol http url "www.youtube.com"
match protocol http url "*youtube*"
match protocol http url "*youtube.com*"
class-map match-all v40
match any
match access-group 140
class-map match-all v80
match any
match access-group 180
policy-map torrent.drop
class torrent
  drop
policy-map youtube.drop
class youtube
  drop
policy-map vlans.limit
class v40
  police cir 3500000 bc 1500000
   conform-action transmit
   exceed-action drop
  service-policy youtube.drop
class v80
  police cir 2500000 bc 1000000
   exceed-action drop
  service-policy torrent.drop
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description ISP_WAN_INTERFACE
no ip address
load-interval 600
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/1
description LAN_INTERFACE
ip nbar protocol-discovery
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
load-interval 600
duplex auto
speed auto
service-policy output vlans.limit
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
load-interval 60
dialer pool 1
ppp authentication pap callin
ppp pap sent-username 14356861 password 0 14356861
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 192.168.40.0 255.255.255.0 192.168.1.2
ip route 192.168.80.0 255.255.255.0 192.168.1.2
access-list 1 permit 192.168.0.0 0.0.255.255
access-list 140 permit ip any 192.168.40.0 0.0.0.255 time-range DayHours
access-list 180 permit ip any 192.168.80.0 0.0.0.255 time-range DayHours
control-plane
mgcp profile default
gatekeeper
shutdown
line con 0
password tropico
logging synchronous
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
exec-timeout 30 0
password tropico
login
transport input all
scheduler allocate 20000 1000
time-range DayHours
periodic Sunday 9:00 to Monday 2:00
periodic Monday 9:00 to Tuesday 2:00
periodic Tuesday 9:00 to Wednesday 2:00
periodic Wednesday 9:00 to Thursday 2:00
periodic Thursday 9:00 to Friday 2:00
periodic Friday 1:00 to Saturday 2:00
periodic Saturday 9:00 to Sunday 2:00
end
I have also tried blocking youtube using the nbar command below but no luck so far.
match protocol youtube
Abdul,
mahmoodmkl
Level 7
Level 7
can u apply this policy inbound n try
mahmoodmkl
Level 7
Level 7
Mahmoodmkl,
Tried it, still doesn't work.
Abdul,
Mahmoodmkl,
Actually, after applying the policy inbound as you have suggested, it worked after i restarted the router.
Thanks for your help.
Abdul,
