12-28-2012 12:29 PM - edited 03-04-2019 06:31 PM
Hy Guys, I have one router 2911 with the following image
c2900-universalk9-mz.SPA.151-4.M4.bin
I have two IPS on this routers and I tried to configure the IP SLA on this and I`m not able to do it and I don´t know why.
I can configure almost everything but not the IP SLA command.
this is the config:
track 10 ip sla 1 reachability
delay down 10 up 1
track 20 ip sla 2 reachability
delay down 10 up 1
interface GigabitEthernet0/0
no ip address
no ip route-cache
duplex full
speed 1000
interface GigabitEthernet0/0.10
description LAN DATOS INT
encapsulation dot1Q 10
ip address 192.168.13.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
no ip route-cache
ip policy route-map PBR
interface GigabitEthernet0/0.20
description VOICE VLAN INT
encapsulation dot1Q 20
ip address 192.168.14.1 255.255.255.0
no ip route-cache
interface GigabitEthernet0/1
description WAN TO METROTEL
ip address 190.104.197.90 255.255.255.248
ip nat outside
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/2
description WAN2 TO SION
ip address 216.244.210.26 255.255.255.248
ip nat outside
duplex auto
speed auto
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map METROTEL interface GigabitEthernet0/1 overload
ip nat inside source route-map SION interface GigabitEthernet0/2 overload
ip route 0.0.0.0 0.0.0.0 190.104.197.89 track 10
ip route 0.0.0.0 0.0.0.0 216.244.210.25 track 20
ip sla key-chain 1
access-list 10 permit 192.168.13.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 100 permit ip any any
route-map SION permit 10
match ip address 10
match interface GigabitEthernet0/2
route-map METROTEL permit 10
match ip address 10
match interface GigabitEthernet0/1
route-map PBR permit 10
match ip address 100
set ip next-hop verify-availability 216.244.210.25 1 track 20
route-map PBR permit 30
set ip next-hop verify-availability 190.104.197.89 2 track 10
and when I try to configure the IP SLA shows this:
RTLATCOM(config)#ip sla 1
% Invalid input detected at '^' marker.
and this followings options:
RTLATCOM(config)#ip sla ?
key-chain Use MD5 Authentication for IP SLAs Control Messages
responder Enable IP SLAs Responder
server IPPM server configuration
What I need to do in this case? or why cannot configure the IP SLA?
Thanks in advance
gonzalo
Solved! Go to Solution.
12-28-2012 12:43 PM
You'll need a data license for it to support sla. Can you post "show version"? There's a chart at the bottom that will show you what you're licensed for. You'll want to see a "permanent" status in the data row.
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc None None None
data datak9 Permanent datak9
HTH,
John
*** Please rate all useful posts ***
12-28-2012 12:58 PM
Hi Gonzalo,
Here is the link which provides the details about the licnese and the featured supported by the different licenses on the ISRG2 routers.
http://www.cisco.com/en/US/prod/collateral/routers/ps10616/white_paper_c11_556985.html
You can check the license activated on the router using "sh ver" it will show you at the end of the show version output or you can check "sh license all".
You can enable the evaluation data license using the below mentioned command in the config mode.
license boot module c2900 technology-package datak9
But it will get expire after 60 days the details are there in the above links.
You need to boot the router after configuring the above comand to activate the specified license.
Paresh
12-28-2012 12:43 PM
uc None None None
HTH,
John
12-28-2012 12:59 PM
Hi John, thanks for your answer, this is the chart.
uc None None None
data None None None
so, I need the DATA license, I need pay for this? or is a change in the cisco license portal? I`m reading a post right now but i cannot understand if it´s with cost.
Thank you very much for your help.
12-28-2012 12:58 PM
Hi Gonzalo,
Paresh
12-28-2012 01:24 PM
Thanks for your comments Paresh!!!
12-28-2012 03:10 PM
Yes there will be a cost for it. I had to do the same exact thing recently :) I don't remember how much it was, but your reseller should be able to help you out.
