Cannot logon with ssh
interfacedy
Hi Do not know why cannot logon to Catalyst 9800 by ssh. The configuration for ssh is correct, but cannot login. When trying to login, I got the below error message and then I still can type some commands but cannot get any response. Please see the below. Thank you
6 Replies 6
interfacedy
Hi We do not know why cannot logon to Catalyst 9800 vWLC by ssh via CRT. The configuration for ssh is correct, but cannot login. When trying to login, I got the below error message and then I still can type some commands but cannot get any response. Please see the below. Not sure if it is ssh issue or vWLC issue. Thank you
are accessible through vmconsole, are gui accessible.
vm console can work, but it cannot copy. thank you
balaji.bandi
Make sure you configured SSH config :
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/config-guide/b_wl_16_10_cg/secure-shell.html
check from GUI going to Command level :
GUI, under Administration > Command Line Interface, run the following commands and provide the output
- show ip ssh
- show run
username admin privilege 15 password 0 Bandi123
enable secret 9 XXXXXXXXXXXXXXXXXXX
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
BB
Thank you for your reply, I did configuration based on the link document. Do not know where the wrong config is. Maybe we need some debug commands to find it out.
Sat May 08 2021 15:48:26 GMT-0400 (Eastern Daylight Time)
#show ip ssh
SSH Enabled - version 2.0
Authentication methods:publickey,keyboard-interactive,password
Authentication Publickey Algorithms:x509v3-ssh-rsa,ssh-rsa,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,x509v3-ecdsa-sha2-nistp256,x509v3-ecdsa-sha2-nistp384,x509v3-ecdsa-sha2-nistp521,rsa-sha2-256,rsa-sha2-512
Hostkey Algorithms:x509v3-ssh-rsa,rsa-sha2-512,rsa-sha2-256,ssh-rsa
Encryption Algorithms:aes128-gcm,aes256-gcm,aes128-ctr,aes192-ctr,aes256-ctr
MAC Algorithms:hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha2-256,hmac-sha2-512
KEX Algorithms:ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group14-sha1
Authentication timeout: 120 secs; Authentication retries: 3
Minimum expected Diffie Hellman key size : 2048 bits
IOS Keys in SECSH format(ssh-rsa, base64 encoded): TP-self-signed-1244097669
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCa/0WZXEs2M55FNjegNKEkzu4TcNO4y3m8P3xXckQN
F4UBQGG53Zm+Mifqa6CTzpLzTMBlCcchgmSYHRIAZa9pZDP1xQgKQfAS4xKhE8lg3XPlSljir52noTh5
0JCDoPt7QV1q9LqcUQ9qhVM3U1jfSIYjg5Vxaen3AMbKBEWfrUewA4L2V/weBrTmEnR3DgxDUazD9kcc
F6n/0UMmXwtEAT2JBO8rcaTaHuM5TmoTW0meJ6scV4AExiZRAV1kIpwfpQscPkW45gU2Kp032o1i6kdn
LLxDiqr3xxzkgVRXw7QDUiS1i02eMBEuk4o4iSTZyzv6kV6BrF5tCPJGLLpD
username admin privilege 15 password 0 Abcd123
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
Can you post show run - are you able to access GUI without any issue right ?
BB
