Cannot ping between routers
ITgrad
I'm a third year comp-sci student, and having trouble with some basic setup of my network in packet tracer. My main issue is that I cannot send packets between ACMER1 to ACMER2, and ACMER1 to ACMER3. I am pretty sure I'm supposed to implement some variation of a static route, but for the life of me cannot figure out why I can't get it to work. I am sure this a simple fix and that I'll kick myself if I figure it out.
My network topology: setup.PNG
Here are my "show running-config"'s below:
ACMER1:
Current configuration : 1451 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
service password-encryption
hostname Router
login block-for 300 attempts 2 within 120
enable secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
no ip cef
Router#
Router#
Router#show running-config
Building configuration...
version 12.4
hostname Router
no ip cef
no ipv6 cef
username ACMER1 password 7 0822455D0A16
no ip domain-lookup
spanning-tree mode pvst
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.1.18.126 255.255.255.128
duplex auto
speed auto
interface Serial0/0/0
ip address 172.16.1.153 255.255.255.252
clock rate 2000000
interface Serial0/0/1
ip address 172.16.0.73 255.255.255.252
encapsulation ppp
ppp authentication chap
clock rate 2000000
interface Vlan1
no ip address
shutdown
router ospf 1
router-id 1.1.1.1
log-adjacency-changes
network 10.1.18.0 0.0.0.127 area 1
network 172.16.1.152 0.0.0.3 area 0
network 172.16.0.72 0.0.0.3 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 0.0.0.0
ip flow-export version 9
ip access-list extended sl_def_acl
deny tcp any any eq telnet
deny tcp any any eq www
deny tcp any any eq 22
permit tcp any any eq 22
no cdp run
banner motd ^C
This router is managed by 1404956 ^C
line con 0
login
line aux 0
line vty 0 4
access-class TELNET in
login
line vty 5 15
login
end-------------------------------------------------
version 15.1
hostname Router
logging userinfo
no ip cef
no ipv6 cef
username ACMER2 password 7 0822455D0A16
license udi pid CISCO2911/K9 sn FTX15240EF0
license boot module c2900 technology-package securityk9
no ip domain-lookup
interface GigabitEthernet0/0
ip address 202.202.18.155 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
shutdown
ip address 172.16.0.74 255.255.255.252
encapsulation ppp
clock rate 2000000
ip address 172.16.2.73 255.255.255.252
clock rate 2000000
interface Serial0/1/0
no ip address
clock rate 2000000
shutdown
interface Serial0/1/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
ip classless
no cdp run
banner motd ^C
no logging trap
line con 0
login
line aux 0
line vty 0 4
login
line vty 5 15
login
ACMER3
Current configuration : 900 bytes
version 12.4
hostname Router
no ip cef
no ipv6 cef
no ip domain-lookup
ip address 10.2.21.126 255.255.255.128
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
ip address 172.16.1.154 255.255.255.252
clock rate 2000000
ip address 172.16.2.74 255.255.255.252
interface Vlan1
no ip address
shutdown
ip classless
no cdp run
line con 0
login
line aux 0
line vty 0 4
login
line vty 5 15
login
Any help/guidence is greatly appreciated
42 Replies 42
So upon further inspection of my network, even without CHAP authentication, the routers won't recodnise one another as ospf neighbors, aside ACMER2 & 3 seeing one another
Hi @ITgrad
Please, share the output of "show ip ospf interface serial x/x" from both router plase.
-If I helped you somehow, please, rate it as useful.-cupons extracupons extracupons extra
It would also help if you post the output of show ip interface brief from each of the routers.
Rick
Rick
ACMER1
Router#show ip int brief
FastEthernet0/0 unassigned YES manual up down
FastEthernet0/1 10.1.18.126 YES manual up up
Serial0/0/0 172.16.1.153 YES manual up up
Serial0/0/1 172.16.0.73 YES manual up up
Vlan1 unassigned YES unset administratively down down
ACMER2
GigabitEthernet0/0 202.202.18.155 YES manual up up
GigabitEthernet0/1 unassigned YES unset administratively down down
GigabitEthernet0/2 unassigned YES unset administratively down down
Serial0/0/0 172.16.0.74 YES manual up up
Serial0/0/1 172.16.2.73 YES manual up up
Serial0/1/0 unassigned YES unset administratively down down
Serial0/1/1 unassigned YES unset administratively down down
ACMER3
FastEthernet0/0 10.2.21.126 YES manual up down
FastEthernet0/1 unassigned YES unset administratively down down
Serial0/0/0 172.16.1.154 YES manual up up
Serial0/0/1 172.16.2.74 YES manual up up
I've started from scratch; same IP addresses, same static routes, and same subnets. OSPF has been implemented, but ppp & CHAP has been left out this time. I still have the same issue, that ACMER 2&3 see one another as neighbors, but the others do not. I've run the "show ip ospf neighbor" command, and this confirms my problem. I can ping between all three routers, but when I try and ping from the work station connected to ACMER1, to ACMER2, it fails.
I asked for "show ip ospf interface serial x/x
Can you provide?
do you want the results for each serial interface on all three routers?
apologies for late reponse also
Dont worry.
 From router you are trying to peer up with OSPF. Those two serial interfaces connected each other.
apologies, but that last post needs to be re-phrased, I can't understand it........again, apologies
Alright.
On router ACMER2 you run:
show ip ospf interface  Serial0/0/1
On router ACMER3 you run:
It might provide helpful information to run debug ip ospf adjacency
Rick
Rick
I've managed to get everything working, turns out I made a rookie error; slight incorrections in my IP addressing. You're guidence and suggestions helped me to this discovery, so I thank you all!
You are welcome. I am glad that our suggestions were helpful. Thank you for posting back to the forum to let us know that you have resolved the problem and that it was issues in the configuration of IP addressing on the interfaces.
Rick
Rick
