Cannot ping between routers
ITgrad
I'm a third year comp-sci student, and having trouble with some basic setup of my network in packet tracer. My main issue is that I cannot send packets between ACMER1 to ACMER2, and ACMER1 to ACMER3. I am pretty sure I'm supposed to implement some variation of a static route, but for the life of me cannot figure out why I can't get it to work. I am sure this a simple fix and that I'll kick myself if I figure it out.
My network topology: setup.PNG
Here are my "show running-config"'s below:
ACMER1:
Current configuration : 1451 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
service password-encryption
hostname Router
login block-for 300 attempts 2 within 120
enable secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
no ip cef
Router#
Router#
Router#show running-config
Building configuration...
version 12.4
hostname Router
no ip cef
no ipv6 cef
username ACMER1 password 7 0822455D0A16
no ip domain-lookup
spanning-tree mode pvst
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.1.18.126 255.255.255.128
duplex auto
speed auto
interface Serial0/0/0
ip address 172.16.1.153 255.255.255.252
clock rate 2000000
interface Serial0/0/1
ip address 172.16.0.73 255.255.255.252
encapsulation ppp
ppp authentication chap
clock rate 2000000
interface Vlan1
no ip address
shutdown
router ospf 1
router-id 1.1.1.1
log-adjacency-changes
network 10.1.18.0 0.0.0.127 area 1
network 172.16.1.152 0.0.0.3 area 0
network 172.16.0.72 0.0.0.3 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 0.0.0.0
ip flow-export version 9
ip access-list extended sl_def_acl
deny tcp any any eq telnet
deny tcp any any eq www
deny tcp any any eq 22
permit tcp any any eq 22
no cdp run
banner motd ^C
This router is managed by 1404956 ^C
line con 0
login
line aux 0
line vty 0 4
access-class TELNET in
login
line vty 5 15
login
end-------------------------------------------------
version 15.1
hostname Router
logging userinfo
no ip cef
no ipv6 cef
username ACMER2 password 7 0822455D0A16
license udi pid CISCO2911/K9 sn FTX15240EF0
license boot module c2900 technology-package securityk9
no ip domain-lookup
interface GigabitEthernet0/0
ip address 202.202.18.155 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
shutdown
ip address 172.16.0.74 255.255.255.252
encapsulation ppp
clock rate 2000000
ip address 172.16.2.73 255.255.255.252
clock rate 2000000
interface Serial0/1/0
no ip address
clock rate 2000000
shutdown
interface Serial0/1/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
ip classless
no cdp run
banner motd ^C
no logging trap
line con 0
login
line aux 0
line vty 0 4
login
line vty 5 15
login
ACMER3
Current configuration : 900 bytes
version 12.4
hostname Router
no ip cef
no ipv6 cef
no ip domain-lookup
ip address 10.2.21.126 255.255.255.128
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
ip address 172.16.1.154 255.255.255.252
clock rate 2000000
ip address 172.16.2.74 255.255.255.252
interface Vlan1
no ip address
shutdown
ip classless
no cdp run
line con 0
login
line aux 0
line vty 0 4
login
line vty 5 15
login
Any help/guidence is greatly appreciated
42 Replies 42
Line up protocol down is can be Layer two protocol problem and not OSPF. I saw you tried to use PPP but you can also use HDLC which is Cisco´s default Serial Link encapsulation.
 Try to do not specify the encapsulation, unless you really need PPP. Then, enable OSPF as it should and let me know.
-If I helped you somehow, please, rate it as useful.-
I am required to use PPP and CHAP authentification annoyingly: below is the outline of where I am supposed to use it:
Task 2: Configure and Activate Serial and Ethernet Addresses
Configure all devices with IP addresses using Table 1 and your individual address assignments (obtained from your individual web page). Assign appropriate default gateways to the end clients.
Note that Net12 and the network between ACMEGateway and ISP must use PPP with CHAP authentication. The password must be “cisco”.
I have removed CHAP authentification on the routers in the AMCER network, and now I can ping between them. Thank you guys ever so much!
but now how do I implement CHAp authentification without disrupting communication
You need to define username and password.
 Follow this for both router:
R1(config)#username R2 password CISCO
R1(config)#int s1/1
R1(config-if)#ppp authentication chap
R2(config)#username R1 password CISCO
R2(config)#int s1/1
R2(config-if)#ppp authentication chap
when I implement these commands on the required routers (ACMER1, s0/0/1 and ACMER2, s0/0/0), the connection between the routers goes into a "down" state
share the config again please.
The debug reports?
I've made sure that the passwords are the same for the CHAP authentication, and that the username is that of the other router
Can be show run from both router.
Current runnoing configs
ACMER1
ACMER1#show running-config
Current configuration : 1571 bytes
version 12.4
hostname ACMER1
no ip cef
no ipv6 cef
username AMCER1 password 7 0822455D0A16
username R1 password 7 0822455D0A16
no ip domain-lookup
no ip address
duplex auto
speed auto
duplex auto
speed auto
clock rate 2000000
encapsulation ppp
clock rate 2000000
interface Vlan1
no ip address
shutdown
router ospf 1
router-id 1.1.1.1
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.0.74
no cdp run
banner motd ^C
line con 0
login
line aux 0
line vty 0 4
login
line vty 5 15
login
ACMER2
Current configuration : 1628 bytes
version 15.1
hostname ACMER2
logging userinfo
no ip cef
no ipv6 cef
no ip domain-lookup
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
encapsulation ppp
clock rate 2000000
clock rate 2000000
no ip address
clock rate 2000000
shutdown
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
router-id 2.2.2.2
network 172.16.2.72 0.0.0.3 area 0
network 202.202.18.128 0.0.0.127 area 2
ip classless
no cdp run
banner motd ^C
no logging trap
line con 0
login
line aux 0
line vty 0 4
login
line vty 5 15
login
On Router ACMER1  you need only this:
delete this:
On the Router ACMER2  you need this:
Delete this:
Lets see now.
After making the changes, I still cannot ping between routers. I've triple checked that the usernames & passwords are correct.
@ITgrad
 I just got this to work on the Packet Tracer. Please find attached.
Try to compare with your config and make the necessary adjustment. Packet Tracer is a bit limited to play with PPP as we dont have all the commands available but it works.
Unfortunately my Packet Tracer did not open your file due version conflict.
I tried the 0 before the password, but it didn't help.
I'm sure there isn't anything else in those configs that I havent tried at this point.
Still have no idea sadly :(
That's weird. Mine worked seamlessly.
Try to pickup another project and start over with new router.
 This is supposed to be easy.
Perhaps a debug on ppp negotiation and/or chap authentication might show what is going on?
In previous posts there seems to be suggestion that the line protocol down might be related to configuring OSPF on the interface. That is highly unlikely to be the case. Line protocol up or down is a layer 2 function and configuring OSPF is a layer 3 function.  Line protocol down might be caused by problems with interface clocking, or might be caused by mismatched protocols on the interface (HDLC on one side and PPP on the other), or failure of hello messages. But if it is true (as I understand one of the previous posts to say) that removing chap authentication allows the interface to come to state up/up and then ping is successful, then clearly the problem is an issue about chap authentication. That is the immediate issue that we need to solve.
Rick
Rick
