Cannot ping from Server1 to PC0
bedros
Hi, I'm new to Cisco networking and have been running into an issue with a simple network I've set up in Packet Tracer. I want to ping from Server1 to PC0 (or vice versa), but It's just not able to. Please see the diagram in this post. I cannot seem to figure out what the issue is, I've double checked all the routing paths and interfaces and everything seems fine.Screenshot 2024-04-03 113652.png
Here is the link to the pkt file: https://easyupload.io/80gpvx
I would highly appreciate any help.
none of your routers had a route to the 192.168.3.0/24 network. The ASA had no routing at all. I added a default route on the ASA, and the relevant static routes on all routers. Attached the revised file...
Hi, Thank you for your reply. Unfortunately, I still cannot ping from PC0 to Server1 or vice versa
Nevermind, it just took some time to properly work. Thank you!
