Cant ping through firewall cisco
quoc anh
I have my firewall like this:
int gig1/1
nameif inside
ip add 192.168.100.1 255.255.255.0 (switch 0)
no shut
int gig1/2
nameif outside
ip add 200.100.10.1 255.255.255.252 (switch 1)
no shut
int gig1/3
nameif DMZ
security-level 50
ip add 192.168.200.1 255.255.255.0
I've already configured route to outside
route outside 0.0.0.0 0.0.0.0 200.100.10.2
router rip
ver 2
no au
net 192.168.100.0
The problem is I cant ping from pc0, (inside 192.168.100.2) to pc5, (outside 200.100.10.2)
Please help me !!
You need to make secuirty level for Inside to be 100
And also ypu need icmp inspection under policy map
MHM
You will also need an ACL that explicitly permits the ICMP echo-reply return from the lower security interface to the higher security interface.
balaji.bandi
If the switch know how to reach back to 192.168.100.0/24 network, i see you have configured RIP, Hope you RIP working,
try simple command :
fixup protocol icmp
BB
