Cannot ping its own router interface
andromeda
Hello everyone,
I must be missing something basic here but here is the issue:
Have 2 cisco routers interconnected via
Gig interfaces 0/0, configured with 10.10.10.1/24 (R1) and 10.10.10.2/24 (R2)
sh ip
int bri reveals on each router the
Gig 0/0
being up up, however I cannot ping the local interfaces from each router?
sh ip
route reveals on each router a C route
10.10.10.0/24 via G0/0 and L 10.10.10.1/32 via G0/0
What Am I missing in this so basic scenario?
Thanks!
try and remove:
ip verify unicast source reachable-via any
on both interfaces...
7 Replies 7
Richard Burts
You have given us a general description but not enough detail for us to understand the issue or to give you good advice. It might help us if you would provide these things from each of the routers:
- configuration of interface Gi0/0
- output of the command show interface Gi0/0
- output of the command show cdp neighbor
- show arp
Rick
Rick
Thanks Richard.
FWA<------->R1<------>R2<------>FWB
I can ping from FWA to FWB, and from FWB to FWA, all static routes in place ok.
R1 connect to R2 via 10.10.10.0/24.
R1: sh run int G0/0
ip address 10.10.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ping R2's G0/0 (10.10.10.2) ok
ping 10.10.10.1 NOT ok
sh cdp neigh
devide ID             Local Interface      Hold time Capability   Platform    Port  ID
R2                        G0/0                    167              RSI         Cisco3925   G0/0
R2: sh run int G0/0
ip address 10.10.10.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ping R1's G0/0 (10.10.10.1) ok
ping 10.10.10.2 NOT ok
sh cdp neigh
R1                        G0/0                    170              RSI         Cisco3925   G0/0
try and remove:
Thanks this worked! Now trying to fig out why?
This is a bit after the fact, and congratulations to @Georg Pauwen for suggesting removal of ip verify unicast, but let us try to clarify a few things about this issue. Using a straight through cable would not cause this kind of issue. Depending on the platform (and perhaps version of code) it could cause the routers to not be able to communicate with each other. In fact it was that type of possible issue that I was looking for when I asked for the information that you posted. Especially show cdp neighbor would show whether the routers were able to communicate at layer 2 and could indicate that it was a layer 3 issue. (which did turn out to be the case) I had not correctly understood the issue. I had assumed that the issue was not being able to ping the neighbor address. Your additional information made it clear that pinging the neighbor address did work and the problem was pinging your own address.
The issue was the effect of ip verify unicast. This command is used to improve security in the network and looks for "spoofed" packets. When the simple version of that command is used one result is that you can no longer ping your own interface. This discussion from the Cisco Learning Network has a nice explanation of why that is the case.
https://learningnetwork.cisco.com/thread/121952
and it shows the optional parameter which can be used so that you can protect your network and still be able to ping your own interface.
Rick
Rick
is this a real network with real routers or a simuator ? Are you using a cross cable for connecting the two routers ?
Thanks. Cant check that now, as Im not there...Real network.
Will the use of straight thru cable between the 2 routers cause this type of issue (ping the remote end but not its own IP)?  remember I can ping from FWAto FWB through these 2 routers...Thought they were autonsensing?
