Cannot route to internet from Switch
NathanLKoch
Here are my configs for my
Router:
version 15.7
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname NASA
boot-start-marker
boot-end-marker
security authentication failure rate 10 log
security passwords min-length 6
logging console critical
enable secret 5
enable password 7
aaa new-model
aaa authentication login local_auth local
aaa session-id common
no ip source-route
no ip gratuitous-arps
ip dhcp excluded-address 192.168.20.1 192.168.20.60
ip dhcp excluded-address 192.168.30.1 192.168.30.60
ip dhcp excluded-address 192.168.40.1 192.168.40.60
ip dhcp excluded-address 192.168.50.1 192.168.50.60
ip dhcp excluded-address 192.168.60.1 192.168.60.60
ip dhcp excluded-address 192.168.70.1 192.168.70.60
ip dhcp excluded-address 192.168.80.1 192.168.80.60
ip dhcp pool vlan 20
 network 192.168.20.0 255.255.255.0
 default-router 192.168.20.1
 dns-server 208.67.222.222 208.67.220.220
ip dhcp pool vlan 30
 network 192.168.30.0 255.255.255.0
 default-router 192.168.30.1
ip dhcp pool vlan 40
 network 192.168.40.0 255.255.255.0
 default-router 192.168.40.1
ip dhcp pool vlan 50
 network 192.168.50.0 255.255.255.0
 default-router 192.168.50.1
ip dhcp pool vlan 60
 network 192.168.60.0 255.255.255.0
 default-router 192.168.60.1
ip dhcp pool vlan 70
 network 192.168.70.0 255.255.255.0
 default-router 192.168.70.1
ip dhcp pool vlan 80
 network 192.168.80.0 255.255.255.0
 default-router 192.168.80.1
no ip bootp server
ip host JPL 192.168.2.2
ip cef
login block-for 13500 attempts 35 within 13500
no ipv6 cef
license udi pid CISCO2911/K9 sn FGL1741129H
license accept end user agreement
license boot module c2900 technology-package securityk9
license boot module c2900 technology-package datak9
vtp mode transparent
username user password 7
redundancy
no cdp run
class-map type inspect match-all INSIDE-TO-OUTSIDE-CLASS
 match access-group name INSIDE-TO-OUTSIDE
class-map type inspect match-all OUTSIDE-TO-INSIDE-CLASS
 match access-group name OUTSIDE-TO-INSIDE
policy-map type inspect INSIDE-TO-OUTSIDE-POLICY
 class type inspect INSIDE-TO-OUTSIDE-CLASS
  pass
 class class-default
  pass
policy-map type inspect OUTSIDE-TO-INSIDE-POLICY
 class type inspect OUTSIDE-TO-INSIDE-CLASS
  drop
 class class-default
  drop
zone security INSIDE
zone security OUTSIDE
zone-pair security IN-TO-OUT source INSIDE destination OUTSIDE
 service-policy type inspect INSIDE-TO-OUTSIDE-POLICY
zone-pair security OUT-TO-IN source OUTSIDE destination INSIDE
 service-policy type inspect OUTSIDE-TO-INSIDE-POLICY
interface Loopback0
interface Embedded-Service-Engine0/0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 shutdown
 no mop enabled
interface GigabitEthernet0/0
 ip address dhcp
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 zone-member security OUTSIDE
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/1
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 zone-member security INSIDE
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/1.1
 encapsulation dot1Q 1 native
 ip address 192.168.2.1 255.255.255.0
 no cdp enable
interface GigabitEthernet0/1.20
 encapsulation dot1Q 20
 ip address 192.168.20.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 no cdp enable
interface GigabitEthernet0/1.30
 encapsulation dot1Q 30
 ip address 192.168.30.1 255.255.255.0
 no cdp enable
interface GigabitEthernet0/1.40
 encapsulation dot1Q 40
 ip address 192.168.40.1 255.255.255.0
 no cdp enable
interface GigabitEthernet0/1.50
 encapsulation dot1Q 50
 ip address 192.168.50.1 255.255.255.0
 no cdp enable
interface GigabitEthernet0/1.60
 encapsulation dot1Q 60
 ip address 192.168.60.1 255.255.255.0
 no cdp enable
interface GigabitEthernet0/1.70
 encapsulation dot1Q 70
 ip address 192.168.70.1 255.255.255.0
 no cdp enable
interface GigabitEthernet0/1.80
 encapsulation dot1Q 80
 ip address 192.168.80.1 255.255.255.0
 no cdp enable
interface GigabitEthernet0/2
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 shutdown
 duplex auto
 speed auto
 no mop enabled
router rip
 version 2
 network 142.165.0.0
 network 192.168.2.0
 network 207.47.196.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 dhcp
ip identd
ip access-list extended INSIDE-TO-OUTSIDE
ip access-list extended OUTSIDE-TO-INSIDE
logging trap debugging
logging facility local2
dialer-list 1 protocol ip permit
ipv6 ioam timestamp
control-plane host
control-plane
 vstack
banner login ^C
*****        ********* *****              ********************  *****              *****     ^C
banner motd ^C
Welcome to ^C
line con 0
 exec-timeout 5 0
 login authentication local_auth
 transport output telnet
 speed 115200
line aux 0
 exec-timeout 15 0
 modem InOut
 transport input telnet
 flowcontrol hardware
line 2
 exec-timeout 15 0
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 password 7
 transport input none
scheduler allocate 20000 1000
end
Switch:
version 15.0
no service pad
service compress-config
hostname JPL
boot-start-marker
boot host bootflash:startup-config
boot system bootflash:startup-config
boot config bootflash:startup-config
boot-end-marker
enable secret 5
enable password 7
username user privilege 15 password 7
no aaa new-model
ip subnet-zero
ip vrf mgmtVrf
vtp domain test-02
power redundancy-mode redundant
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
vlan 20,30,40,50,60,70,80,159-160
interface FastEthernet1
 ip vrf forwarding mgmtVrf
 no ip address
 speed auto
 duplex auto
interface GigabitEthernet1/1
 switchport access vlan 20
 switchport mode dot1q-tunnel
 no cdp enable
interface GigabitEthernet1/2
 switchport mode access
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface GigabitEthernet1/5
interface GigabitEthernet1/6
interface GigabitEthernet1/7
interface GigabitEthernet1/8
interface GigabitEthernet1/9
interface GigabitEthernet1/10
interface GigabitEthernet1/11
interface GigabitEthernet1/12
interface GigabitEthernet1/13
 switchport access vlan 30
interface GigabitEthernet1/14
interface GigabitEthernet1/15
interface GigabitEthernet1/16
interface GigabitEthernet1/17
interface GigabitEthernet1/18
interface GigabitEthernet1/19
interface GigabitEthernet1/20
interface GigabitEthernet1/21
interface GigabitEthernet1/22
interface GigabitEthernet1/23
interface GigabitEthernet1/24
interface GigabitEthernet1/25
 switchport access vlan 40
interface GigabitEthernet1/26
interface GigabitEthernet1/27
interface GigabitEthernet1/28
interface GigabitEthernet1/29
interface GigabitEthernet1/30
interface GigabitEthernet1/31
interface GigabitEthernet1/32
interface GigabitEthernet1/33
interface GigabitEthernet1/34
interface GigabitEthernet1/35
interface GigabitEthernet1/36
interface GigabitEthernet1/37
 switchport access vlan 50
interface GigabitEthernet1/38
interface GigabitEthernet1/39
interface GigabitEthernet1/40
interface GigabitEthernet1/41
interface GigabitEthernet1/42
interface GigabitEthernet1/43
interface GigabitEthernet1/44
interface GigabitEthernet1/45
 media-type rj45
interface GigabitEthernet1/46
 media-type rj45
interface GigabitEthernet1/47
 media-type rj45
interface GigabitEthernet1/48
 switchport mode trunk
 media-type rj45
interface Vlan1
 ip address 192.168.2.2 255.255.255.0
 spanning-tree portfast
 spanning-tree link-type shared
router rip
 network 192.168.2.0
ip route 0.0.0.0 0.0.0.0 192.168.2.1
no ip http server
control-plane
banner login ^C
 ****************,  ****.                ****************, ^C
banner motd ^C
 Welcome to ^C
line con 0
 login local
 stopbits 1
line vty 0 5
 login local
end
Any ideas?
"Fortune favors the brave."
2 Accepted Solutions
I still think the problem is at the zone-based firewall configuration. You must have permit any any at OUTSIDE-TO-INSIDE acl, because the inspection and droping is done by the policy.
But before exploring further i would rather remove the configuration of zone based firewall below the interfaces to see if the issue is from this and after review the configuration.
It is more efficient to make the pair inside-outside to do "inspect" rather than "pass" (below the class-map), so you would not create another pair outside-inside. In this case it will be stateful and permit from outside only replies for traffic initiated from the inside.
25 Replies 25
RicardoSN
Are you able to ping from your switch, sourcing with the IP 192.168.2.2 to the destination IP 192.168.2.1?. If the pings are successful, then i would think the problem resides on the Router not the Switch. I can't see at the moment any switch related issue. Also, what do you exactly mean by "cannot route to internet", you're already doing it with a static route.
-Ricardo S.N., Regards!
Yes. Pings work.
NASA#ping google.com
Sending 5, 100-byte ICMP Echos to 172.217.164.206, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 48/52/64 ms
NASA#ping 192.168.2.2
Sending 5, 100-byte ICMP Echos to 192.168.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
JPL#ping 192.168.2.1
Sending 5, 100-byte ICMP Echos to 192.168.2.1, timeout is 2 seconds:
JPL#ping 192.168.20.1
Sending 5, 100-byte ICMP Echos to 192.168.20.1, timeout is 2 seconds:
JPL#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Muhammad Awais Khan
I did not see any NAT config here. You are not able to ping from any other vlan to outside right ? And you can ping to internet from outside interface
Correct.
Can you add below to your Router.
access-list 10 permit 192.168.0.0 0.0.255.255
ip nat inside source list 10 interface gi0/0 overload
If worked, then you have to add "ip nat inside" to all the remainining subinterfaces you have in your Router
show run
ip nat inside source list 10 interface GigabitEthernet0/0 overload
NASA#show ip nat statistics
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Peak translations: 1, occurred 00:02:18 ago
Outside interfaces:
  GigabitEthernet0/0
Inside interfaces:
  GigabitEthernet0/1, GigabitEthernet0/1.1, GigabitEthernet0/1.20
Hits: 10  Misses: 0
CEF Translated packets: 10, CEF Punted packets: 0
Expired translations: 1
Dynamic mappings:
-- Inside Source
[Id: 1] access-list 10 interface GigabitEthernet0/0 refcount 0
It worked with you ? Output suggested that translation worked well
No. Not yet. I think it's the switch? If I have nat enabled on the router does the switch need to have it enabled as well?
I still cannot ping from the switch?
NASA#ping 192.168.20.63
Sending 5, 100-byte ICMP Echos to 192.168.20.63, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
JPL#ping 8.8.8.8
JPL#ping 8.8.8.8
JPL#
Post the router configuration again.
Jon
You will need on the wan router interface to put "ip nat outside"
Rate if helpful.
I don't want to post anything redundant that might have been mentioned by others, but have a look at the changes marked in bold. Try and implement those...the assumption is that port 48 on the switch is uplinked to port 0/1 on the router.
Router:
version 15.7
no service pad
hostname NASA
boot-start-marker
boot-end-marker
enable secret 5
enable password 7
aaa new-model
no ip source-route
no ip bootp server
ip cef
no ipv6 cef
redundancy
no cdp run
pass
class class-default
pass
drop
class class-default
drop
interface Loopback0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
no mop enabled
ip address dhcp
--> ip nat outside
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
no mop enabled
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
no mop enabled
--> ip nat inside
no cdp enable
ip nat inside
no cdp enable
--> ip nat inside
no cdp enable
--> ip nat inside
no cdp enable
--> ip nat inside
no cdp enable
--> ip nat inside
no cdp enable
--> ip nat inside
no cdp enable
--> ip nat inside
no cdp enable
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
duplex auto
speed auto
no mop enabled
--> no router rip
version 2
network 142.165.0.0
network 192.168.2.0
no ip http server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 1 permit 192.168.20.0 0.0.0.255
access-list 1 permit 192.168.30.0 0.0.0.255
access-list 1 permit 192.168.40.0 0.0.0.255
access-list 1 permit 192.168.50.0 0.0.0.255
access-list 1 permit 192.168.60.0 0.0.0.255
access-list 1 permit 192.168.70.0 0.0.0.255
access-list 1 permit 192.168.80.0 0.0.0.255
ipv6 ioam timestamp
control-plane host
control-plane
vstack
line con 0
exec-timeout 5 0
speed 115200
line aux 0
exec-timeout 15 0
modem InOut
line 2
exec-timeout 15 0
no exec
stopbits 1
line vty 0 4
password 7
end
Switch:
version 15.0
no service pad
hostname JPL
boot-start-marker
boot-end-marker
enable secret 5
enable password 7
--> no ip routing
no aaa new-model
ip subnet-zero
ip vrf mgmtVrf
vtp domain test-02
no ip address
speed auto
duplex auto
no cdp enable
media-type rj45
media-type rj45
media-type rj45
description Uplink to Router interface GigabitEthernet0/1
media-type rj45
interface Vlan1
ip default-gateway 192.168.2.1
--> no router rip
network 192.168.2.0
--> no ip route 0.0.0.0 0.0.0.0 192.168.2.1
no ip http server
control-plane
line con 0
login local
stopbits 1
line vty 0 5
login local
end
Router
NASA#show run
Building configuration...
Current configuration : 7889 bytes
! Last configuration change at 16:26:49 UTC Wed Jan 15 2020 by nkoch
version 15.7
no service pad
service internal
hostname NASA
boot-start-marker
boot-end-marker
enable secret 5
enable password 7
aaa new-model
no ip source-route
no ip bootp server
ip inspect WAAS flush-timeout 10
ip cef
no ipv6 cef
username  password 7
redundancy
 notification-timer 120000
no cdp run
  pass
 class class-default
  pass
  drop
 class class-default
  drop
interface Loopback0
interface Loopback1
 no ip address
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 shutdown
 no mop enabled
 ip address dhcp hostname NASA
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 ip nat enable
 duplex auto
 speed auto
 no mop enabled
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat inside
 ip nat enable
 duplex auto
 speed auto
 no mop enabled
 ip nat inside
 ip nat enable
 no cdp enable
 ip nat inside
 ip nat enable
 no cdp enable
 no cdp enable
 no cdp enable
 no cdp enable
 no cdp enable
 no cdp enable
 no cdp enable
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 shutdown
 duplex auto
 speed auto
 no mop enabled
no ip http server
ip identd
ipv6 ioam timestamp
control-plane host
control-plane
 vstack
banner login ^C
banner motd ^C
Welcome to ^C
line con 0
 exec-timeout 5 0
 speed 115200
line aux 0
 exec-timeout 15 0
 modem InOut
line 2
 exec-timeout 15 0
 no exec
 stopbits 1
line vty 0 4
 password 7
end
Switch
Current configuration : 5879 bytes
version 15.0
no service pad
hostname JPL
boot-start-marker
boot-end-marker
enable secret 5
enable password 7
username  privilege 15 password 7
no aaa new-model
ip subnet-zero
no ip routing
ip vrf mgmtVrf
vtp domain test-02
 no ip address
 no ip route-cache
 speed auto
 duplex auto
 no cdp enable
 media-type rj45
 media-type rj45
 media-type rj45
 media-type rj45
interface Vlan1
 no ip route-cache
no ip http server
control-plane
banner login ^C
banner motd ^C
 Welcome to ^C
line con 0
 login local
 stopbits 1
line vty 0 5
 login local
end
Still not routing? Thank you for your help.
I see you have zone-based firewall configured. In the inspect policy you defined access list INSIDE-TO-OUTSIDE, but the access list is empty. Please configure permit rules for your subnets like this:
permit ip 192.168.0.0 0.0.255.255 any
