Cannot Ping L2 Management Except From Directly Connect L3 Device
Brennon Duffy
Just as the title says I have the following topology.
I cannot ping the Vlan255 SVI on any of the access switches from any device other than DO-CORE-1 and DO-CORE-2.
I have EIGRP running and have reachability to every IP other than the three SVI's mentioned. I'll provide configs for DO-WAN-1, DO-CORE-1, and DO-ASW-1 below as the others are pretty similar.
DO-WAN-1#sh run
Building configuration...
Current configuration : 3789 bytes
! Last configuration change at 19:29:16 UTC Tue Apr 4 2023
version 15.7
hostname DO-WAN-1
boot-start-marker
boot-end-marker
no aaa new-model
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip icmp rate-limit unreachable
no ip domain lookup
ip cef
no ipv6 cef
key chain EIGRP
key 2
key-string EIGRP_PASSWORD
redundancy
no cdp log mismatch duplex
ip tcp synwait-time 5
interface GigabitEthernet0/0
description ***FROM ACCESS PORT G0/0 TO DO-CORE-1 G0/0***
ip address 100.100.100.1 255.255.255.252
ip authentication mode eigrp 1 md5
ip authentication key-chain eigrp 1 EIGRP
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/3
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router eigrp 1
network 10.10.10.0 0.0.0.255
network 10.10.11.0 0.0.0.255
network 10.10.12.0 0.0.0.255
network 10.10.13.0 0.0.0.255
network 10.10.14.0 0.0.0.255
network 10.10.255.0 0.0.0.255
network 100.100.100.0 0.0.0.3
network 100.100.100.4 0.0.0.3
network 100.100.100.8 0.0.0.3
passive-interface default
no passive-interface GigabitEthernet0/0
eigrp router-id 4.4.4.4
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ipv6 ioam timestamp
control-plane
banner exec ^C
* IOSv is strictly limited to use for evaluation, demonstration and IOS *
* education. IOSv is provided as-is and is not supported by Cisco's *
* Technical Advisory Center. Any use or disclosure, in whole or in part, *
* of the IOSv Software or Documentation to any third party for any *
* purposes is expressly prohibited except as otherwise authorized by *
* Cisco in writing. *
**************************************************************************^C
banner incoming ^C
banner login ^C
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
transport input none
no scheduler allocate
end
DO-CORE-1#sh run
Current configuration : 8970 bytes
! Last configuration change at 19:13:03 UTC Tue Apr 4 2023
version 15.2
service compress-config
hostname DO-CORE-1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
key chain EIGRP
key 2
key chain HSRP
key 1
key-string HSRP_PASSWORD
spanning-tree mode pvst
interface Port-channel1
no switchport
ip address 100.100.100.5 255.255.255.252
interface Port-channel2
description ***FROM TRUNK PORT-CHANNEL2 G1/0-1 TO DO-ASW-1 G0/0-1***
switchport trunk allowed vlan 10-14,255
switchport trunk native vlan 999
switchport mode trunk
switchport nonegotiate
interface Port-channel4
description ***FROM TRUNK PORT-CHANNEL4 G1/2-3 TO DO-ASW-2 G0/0-1***
interface Port-channel6
description ***FROM TRUNK PORT-CHANNEL6 G2/0-1 TO DO-ASW-3 G0/0-1***
description ***FROM ACCESS PORT G0/0 TO DO-WAN-1 G0/0***
no switchport
ip address 100.100.100.2 255.255.255.252
negotiation auto
description ***FROM DO-CORE-2 G0/1-2***
no switchport
no ip address
negotiation auto
channel-group 1 mode active
no switchport
no ip address
negotiation auto
description ***UNUSED***
switchport access vlan 999
switchport mode access
shutdown
negotiation auto
interface GigabitEthernet1/0
negotiation auto
channel-group 2 mode active
interface GigabitEthernet1/1
negotiation auto
interface GigabitEthernet1/2
negotiation auto
channel-group 4 mode active
interface GigabitEthernet1/3
negotiation auto
interface GigabitEthernet2/0
negotiation auto
channel-group 6 mode active
interface GigabitEthernet2/1
negotiation auto
interface GigabitEthernet2/2
shutdown
no negotiation auto
interface GigabitEthernet2/3
shutdown
no negotiation auto
interface GigabitEthernet3/0
shutdown
no negotiation auto
interface GigabitEthernet3/1
shutdown
no negotiation auto
interface GigabitEthernet3/2
shutdown
no negotiation auto
interface GigabitEthernet3/3
shutdown
no negotiation auto
interface Vlan10
description ***IT Department***
ip address 10.10.10.252 255.255.255.0
standby 10 ip 10.10.10.254
standby 10 timers msec 200 msec 750
standby 10 priority 120
standby 10 preempt delay minimum 180
standby 10 authentication md5 key-chain HSRP
interface Vlan11
description ***ACCOUNTING***
ip address 10.10.11.252 255.255.255.0
standby 11 ip 10.10.11.254
standby 11 timers msec 200 msec 750
standby 11 priority 120
standby 11 preempt delay minimum 180
standby 11 authentication md5 key-chain HSRP
interface Vlan12
description ***USER***
ip address 10.10.12.252 255.255.255.0
standby 12 ip 10.10.12.254
standby 12 timers msec 200 msec 750
standby 12 priority 120
standby 12 preempt delay minimum 180
standby 12 authentication md5 key-chain HSRP
interface Vlan13
description ***VOICE***
ip address 10.10.13.252 255.255.255.0
standby 13 ip 10.10.13.254
standby 13 timers msec 200 msec 750
standby 13 preempt delay minimum 180
standby 13 authentication md5 key-chain HSRP
interface Vlan14
description ***IOT***
ip address 10.10.14.252 255.255.255.0
standby 14 ip 10.10.14.254
standby 14 timers msec 200 msec 750
standby 14 preempt delay minimum 180
standby 14 authentication md5 key-chain HSRP
interface Vlan255
ip address 10.10.255.1 255.255.255.0
standby 255 ip 10.10.255.254
standby 255 timers msec 200 msec 750
standby 255 preempt delay minimum 180
standby 255 authentication md5 key-chain HSRP
router eigrp 1
no passive-interface Port-channel1
eigrp router-id 2.2.2.2
ip http server
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
control-plane
banner exec ^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
login
end
D0-ASW-1#sh run
Current configuration : 6169 bytes
! Last configuration change at 19:25:43 UTC Tue Apr 4 2023
version 15.2
hostname D0-ASW-1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
interface Port-channel3
description ***FROM TRUNK PORT-CHANNEL3 G0/2-3 TO DO-CORE-2 G1/0-1***
description ***FROM TRUNK PORT-CHANNEL2 G0/0-1 TO DO-CORE-1 G1/0-1***
negotiation auto
negotiation auto
negotiation auto
channel-group 3 mode active
negotiation auto
switchport access vlan 10
negotiation auto
shutdown
negotiation auto
shutdown
negotiation auto
shutdown
negotiation auto
shutdown
negotiation auto
shutdown
negotiation auto
shutdown
negotiation auto
shutdown
negotiation auto
shutdown
negotiation auto
shutdown
negotiation auto
shutdown
negotiation auto
shutdown
negotiation auto
interface Vlan255
description ***MANAGEMENT***
ip address 10.10.255.3 255.255.255.0
ip default-gateway 10.10.255.254
ip http server
control-plane
banner exec ^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
login
end
 On the access switch, instead this  " ip default-gateway 10.10.255.254"  use this  " ip route 0.0.0.0 0.0.0.0 10.10.255.254"
can you traceroute from WAN to SVI in access SW ??
