se 0/1/0:0 protocol showing down even status up also
mallesh.ch1
MTMI(config-if)#do sh ip int brief
GigabitEthernet0/0/0 10.194.58.8 YES NVRAM down down
GigabitEthernet0/0/1 unassigned YES NVRAM down down
GigabitEthernet0/0/2 unassigned YES NVRAM down down
Serial0/1/0:0 10.194.6.94 YES NVRAM down down
Serial0/1/1:0 unassigned YES unset down down
Serial0/2/0:0 unassigned YES unset down down
Serial0/2/1:0 unassigned YES unset down down
Serial1/0/0 10.194.12.5 YES NVRAM down down
Serial1/0/1 10.194.6.142 YES NVRAM down down
Serial1/0/2 10.194.3.85 YES NVRAM down down
Serial1/0/3 10.194.5.34 YES NVRAM down down
GigabitEthernet0 unassigned YES NVRAM administratively down down
Loopback0 10.194.254.58 YES NVRAM up up
 All the interfaces is shown as down down.
Which means, nothing connected to the interface.
 I did not see any interface as UP down like suggested on  the title.
 Can you confirm?
please find itplease find it
mallesh.ch1
se 0/2/0:0 we changed same configuraion to this interface but same
description SC-MTMI 2MB RCIL
bandwidth 2048
ip address 10.194.6.94 255.255.255.252
I got it
 You need to check both sides.
 Please  share the command
show run interface se 0/2/0:0
Please share from both devices.
