Cannot ping outside IP addresses
Kris McCormick
I think I've overlooked something simple but I can't ping outside IP addresses from within my router. I am able to ping outside addresses from the PCs behind the router. It is only when I am at the router CLI that I cannot ping outside addresses.
Using 14506 out of 262136 bytes
! Last configuration change at 12:35:16 PDT Mon Sep 10 2012 by sitetech
! NVRAM config last updated at 12:35:18 PDT Mon Sep 10 2012 by sitetech
version 15.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname rtr-jag-pd-01
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 warnings
enable secret 4 nqDHNNAboQs3pRtIt7QPcjUYTEPSRmg5GiHQcIb3Uq2
no aaa new-model
clock timezone PST -8 0
clock summer-time PDT recurring
no ipv6 cef
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.48.25.1 10.48.25.63
ip dhcp excluded-address 10.48.26.1 10.48.26.63
ip dhcp excluded-address 10.48.27.1 10.48.27.63
ip dhcp pool voice
network 10.48.26.0 255.255.255.0
default-router 10.48.26.1
option 42 ip 10.48.255.9 10.48.255.254
option 2 hex ffff.8f80
option 156 ascii "ftpservers=10.48.2.16, country=1, language=1, layer2tagging=1, vlanid=102"
dns-server 64.60.0.17
ip dhcp pool data
network 10.48.25.0 255.255.255.0
default-router 10.48.25.1
ip dhcp pool chartwell
network 10.48.27.0 255.255.255.0
default-router 10.48.27.1
no ip bootp server
ip domain lookup source-interface Loopback0
ip domain name JAG
ip name-server 64.60.0.17
ip name-server 64.60.0.18
parameter-map type ooo global
tcp reassembly queue length 64
tcp reassembly memory limit 4096
crypto pki trustpoint TP-self-signed-4286009541
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4286009541
revocation-check none
rsakeypair TP-self-signed-4286009541
crypto pki certificate chain TP-self-signed-4286009541
certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
license udi pid CISCO2901/K9 sn FTX1622Y01L
username sitetech privilege 15 secret 4 nqDHNNAboQs3pRtIt7QPcjUYTEPSRmg5GiHQcIb3Uq2
redundancy
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 1
class-map type inspect match-any SDM_AH
match access-group name SDM_AH
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-all SSH_ACCESS
match access-group name SSH
class-map type inspect match-any ccp-cls-insp-traffic
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
match protocol ntp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any SDM_IP
match access-group name SDM_IP
class-map type inspect match-any SDM_GRE
match access-group name SDM_GRE
class-map type inspect match-any SDM_ESP
match access-group name SDM_ESP
class-map type inspect match-any SDM_DMVPN_TRAFFIC
match protocol isakmp
match protocol ipsec-msft
match class-map SDM_AH
match class-map SDM_GRE
match class-map SDM_ESP
class-map type inspect match-all SDM_DMVPN_PT
match access-group 101
match class-map SDM_DMVPN_TRAFFIC
class-map type inspect match-any Mon-Echo-Svc
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any out-in
match access-group name out-in
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map match-any Call-Signaling
match ip dscp cs3
match ip dscp af31
class-map match-any Voice
match ip dscp ef
match access-group 161
class-map type inspect match-all ccp-cls-ccp-permit-1
match class-map Mon-Echo-Svc
match access-group name RM-Mon-Traffic
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect sdm-permit-gre
class type inspect SDM_GRE
  pass
class class-default
  drop log
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-sip-inspect
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h323annexe-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect ccp-h323nxg-inspect
  inspect
class type inspect ccp-skinny-inspect
  inspect
class class-default
  drop
policy-map type inspect out-in
class type inspect out-in
  inspect
class class-default
  drop
class type inspect SDM_DMVPN_PT
  pass
class type inspect ccp-cls-ccp-permit-1
  inspect
class type inspect SSH_ACCESS
  inspect
class class-default
  drop
policy-map type inspect sdm-permit-ip
class type inspect SDM_IP
  pass
class class-default
  drop log
policy-map WAN-EDGE
class Voice
  priority percent 33
class Call-Signaling
  bandwidth percent 5
class class-default
  fair-queue
zone security dmvpn-zone
zone security in-zone
zone security out-zone
zone-pair security sdm-zp-in-gre1 source in-zone destination dmvpn-zone
service-policy type inspect sdm-permit-ip
zone-pair security ccp-zp-out-self source out-zone destination self
service-policy type inspect ccp-permit
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security sdm-zp-gre-in1 source dmvpn-zone destination in-zone
zone-pair security ccp-zp-out-gre source out-zone destination dmvpn-zone
service-policy type inspect sdm-permit-gre
zone-pair security ccp-zp-gre-out source dmvpn-zone destination out-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security out-in source out-zone destination in-zone
service-policy type inspect out-in
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key (hidden) address 0.0.0.0 0.0.0.0
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 10 periodic
crypto ipsec transform-set jag-trans esp-aes 256 esp-md5-hmac
crypto ipsec profile jag-dmvpn
set transform-set jag-trans
interface Loopback0
description $FW_INSIDE$
ip address 10.48.255.17 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly in
zone-member security in-zone
load-interval 30
interface Tunnel0
description DMVPN via TelePacific$FW_INSIDE$
bandwidth 1000
ip address 10.255.48.18 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1400
ip flow ingress
ip nhrp authentication DMVPN_NW
ip nhrp map multicast 206.82.221.230
ip nhrp map 10.255.48.254 206.82.221.230
ip nhrp network-id 100000
ip nhrp holdtime 30
ip nhrp nhs 10.255.48.254
zone-member security dmvpn-zone
ip tcp adjust-mss 1360
ip summary-address eigrp 1048 10.48.16.0 255.255.252.0
delay 1000
qos pre-classify
tunnel source GigabitEthernet0/0
tunnel mode gre multipoint
tunnel key 100000
tunnel protection ipsec profile jag-dmvpn
interface Null0
no ip unreachables
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description TelePacific Internet$FW_OUTSIDE$
ip address zzz.zzz.zzz.26 255.255.255.248
ip access-group MILLS in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
zone-member security out-zone
load-interval 30
duplex auto
speed auto
no cdp enable
no mop enabled
service-policy output WAN-EDGE
interface GigabitEthernet0/1
description Inside Trunk
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
load-interval 30
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1.101
description PD Data$ETH-LAN$$FW_INSIDE$
encapsulation dot1Q 101
ip address 10.48.25.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
interface GigabitEthernet0/1.102
description PD Voice$ETH-LAN$$FW_INSIDE$
encapsulation dot1Q 102
ip address 10.48.26.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
interface GigabitEthernet0/1.110
description PD Chartwell$ETH-LAN$$FW_INSIDE$
encapsulation dot1Q 110
ip address 10.48.27.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
router eigrp 1048
network 10.0.0.0
network 10.48.0.0 0.0.255.255
network 10.255.48.0 0.0.0.255
network 10.255.49.0 0.0.0.255
passive-interface GigabitEthernet0/0
ip local policy route-map pbr-ping-monitor
no ip forward-protocol nd
no ip forward-protocol udp tftp
no ip forward-protocol udp nameserver
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
ip http server
ip http access-class 90
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat source list 110 interface GigabitEthernet0/0 overload
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source static 10.48.25.1 198.101.110.26
ip nat inside source static tcp 10.48.25.24 80 198.101.110.27 80 extendable
ip nat inside source static tcp 10.48.25.24 443 198.101.110.27 443 extendable
ip nat inside source static tcp 10.48.25.24 4000 198.101.110.27 4000 extendable
ip nat inside source static tcp 10.48.25.24 44000 198.101.110.27 44000 extendable
ip nat inside source static 10.48.25.24 198.101.110.27
ip route 0.0.0.0 0.0.0.0 zzz.zzz.zzz.25
ip access-list extended Mon-Echo-Traffic
remark CCP_ACL Category=128
permit ip xxx.xxx.xxx.224 0.0.0.31 any
ip access-list extended NATIP
deny   ip 10.48.0.0 0.0.255.255 10.0.0.0 0.0.0.255
permit ip 10.48.0.0 0.0.255.255 any
ip access-list extended RM-Mon-Traffic
ip access-list extended SDM_AH
permit ahp any any
ip access-list extended SDM_ESP
permit esp any any
ip access-list extended SDM_GRE
permit gre any any
ip access-list extended SDM_IP
remark CCP_ACL Category=0
permit ip any any
ip access-list extended SSH
permit tcp any any eq 22
ip access-list extended natip
ip access-list extended out-in
permit tcp any host 10.48.25.24 eq 443
permit tcp any host 10.48.25.24 eq 4000
permit tcp any host 10.48.25.24 eq 44000
permit tcp any host 10.48.25.24 eq www
ip access-list extended pbr-ping-TP
permit icmp host zzz.zzz.zzz.26 host xxx.xxx.xxx.230
access-list 1 permit 10.48.0.0 0.0.255.255
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 10.48.0.0 0.0.255.255
access-list 90 remark HTTP Server ACL
access-list 90 permit 10.255.48.0 0.0.0.255
access-list 90 permit 10.48.0.0 0.0.255.255
access-list 90 permit 10.20.0.0 0.3.255.255
access-list 90 permit 10.16.1.0 0.0.0.255
access-list 90 permit xxx.xxx.xxx.224 0.0.0.15
access-list 90 deny   any
access-list 100 permit ip zzz.zzz.zzz.24 0.0.0.3 any
access-list 101 permit ip any host zzz.zzz.zzz.26
access-list 103 remark VTY Access-class list1
access-list 103 permit ip 10.255.48.0 0.0.0.255 any
access-list 103 permit ip 10.48.0.0 0.0.255.255 any
access-list 103 permit ip 10.16.1.0 0.0.0.255 any
access-list 103 permit ip 10.20.0.0 0.3.255.255 any
access-list 103 permit ip xxx.xxx.xxx.224 0.0.0.31 any
access-list 103 deny   ip any any
access-list 110 permit ip 10.48.0.0 0.0.255.255 any
access-list 111 permit ip 10.48.0.0 0.0.255.255 any
access-list 161 remark : ShoreTel Voice over IP Ports
access-list 161 permit udp any any eq 2427
access-list 161 permit udp any any eq 2727
access-list 161 permit udp any any range 5440 5446
access-list 161 permit udp any any eq 5004
access-list 161 permit udp any any eq 5060
access-list 161 permit tcp any any eq 5060
access-list 161 permit udp host 10.48.14.16 gt 1024 any gt 1024
access-list 161 permit udp 10.48.10.0 0.0.0.255 any
control-plane
banner login ^CCThis system is considered private and proprietary and is subject to audit. The unauthorized access, use or modification of this or any other computer systems or networks or of the data contained therein or in transit thereto/therefrom is
Disconnect IMMEDIATELY if you are not an authorized user!
^C
line con 0
login local
transport output telnet
line aux 0
login local
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
ntp server 192.12.19.20
ntp server 164.67.62.194
end
Hi Kris,
good catch, I don't think I would have spotted this easily without debugs.
Glad you solved your problem.
Regards.
Alain
6 Replies 6
cadet alain
Can you add this command to your config:
ip inspect log drop-pkt and tell us if you've got any log output when pinging from the router.
Regards.
Alain
I've added it to the config and did various pings. As expected, none were successful but they didn't show in the log either. I also pinged www.Google.com and the name was resolved but the ping failed. Here is what was recorded:
012298: .Sep 10 15:01:17.611 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012299: .Sep 10 15:02:47.760 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012300: .Sep 10 15:03:47.840 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012301: .Sep 10 15:04:47.916 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012302: .Sep 10 15:05:01.260 PDT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1978490700 1500 bytes is out-of-order; expected seq:1978386444. Reason: TCP reassembly queue overflow - session 10.48.25.168:50848 to 208.85.46.21:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
012303: .Sep 10 15:05:19.772 PDT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:711583619 1500 bytes is out-of-order; expected seq:711487259. Reason: TCP reassembly queue overflow - session 10.48.25.142:49629 to 207.171.187.117:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
012304: .Sep 10 15:06:18.005 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012305: .Sep 10 15:06:37.645 PDT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2064835234 1500 bytes is out-of-order; expected seq:2064740334. Reason: TCP reassembly queue overflow - session 10.48.25.166:53593 to 173.236.199.90:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
012306: .Sep 10 15:07:48.165 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012307: .Sep 10 15:09:18.242 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012308: .Sep 10 15:10:05.894 PDT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:-1727064329 1500 bytes is out-of-order; expected seq:2567808847. Reason: TCP reassembly queue overflow - session 10.48.25.166:53898 to 208.57.239.140:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
012309: .Sep 10 15:10:19.306 PDT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:-1723586546 1500 bytes is out-of-order; expected seq:2571348894. Reason: TCP reassembly queue overflow - session 10.48.25.166:53898 to 208.57.239.140:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
012310: .Sep 10 15:10:33.302 PDT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:13438822 1500 bytes is out-of-order; expected seq:13406702. Reason: TCP reassembly queue overflow - session 10.48.25.142:49714 to 207.171.187.117:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
012311: .Sep 10 15:10:48.394 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012312: .Sep 10 15:12:18.475 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012313: .Sep 10 15:12:26.535 PDT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:-129881396 1500 bytes is out-of-order; expected seq:4165041012. Reason: TCP reassembly queue overflow - session 10.48.25.166:53930 to 208.57.239.143:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
012314: .Sep 10 15:12:29.055 PDT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:-129229796 1500 bytes is out-of-order; expected seq:4165643380. Reason: TCP reassembly queue overflow - session 10.48.25.166:53930 to 208.57.239.143:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
012315: .Sep 10 15:13:48.631 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012316: .Sep 10 15:14:48.711 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012317: .Sep 10 15:16:18.788 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012318: .Sep 10 15:17:48.948 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012321: .Sep 10 15:18:24.332 PDT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:-1772919495 1500 bytes is out-of-order; expected seq:2521951441. Reason: TCP reassembly queue overflow - session 10.48.25.127:52912 to 208.85.46.23:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
012324: .Sep 10 15:19:19.025 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012326: .Sep 10 15:19:56.805 PDT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:-686732709 1500 bytes is out-of-order; expected seq:3608130331. Reason: TCP reassembly queue overflow - session 10.48.25.168:50976 to 209.107.207.34:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
012329: .Sep 10 15:20:49.177 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012332: .Sep 10 15:22:01.901 PDT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1841933159 1500 bytes is out-of-order; expected seq:1841834639. Reason: TCP reassembly queue overflow - session 10.48.25.175:57994 to 207.171.187.117:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
012334: .Sep 10 15:22:19.257 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012336: .Sep 10 15:22:53.858 PDT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:-105094622 1500 bytes is out-of-order; expected seq:4189729594. Reason: TCP reassembly queue overflow - session 10.48.25.175:58037 to 207.171.187.117:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
012338: .Sep 10 15:23:49.410 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012342: .Sep 10 15:25:19.490 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012346: .Sep 10 15:26:49.655 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012349: .Sep 10 15:27:43.371 PDT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1421996587 1500 bytes is out-of-order; expected seq:1421935599. Reason: TCP reassembly queue overflow - session 10.48.25.175:58249 to 65.55.227.209:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
012351: .Sep 10 15:28:19.719 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012354: .Sep 10 15:29:49.880 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012358: .Sep 10 15:31:19.952 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012361: .Sep 10 15:32:50.105 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012365: .Sep 10 15:34:20.189 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012369: .Sep 10 15:35:50.333 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012370: .Sep 10 15:36:13.006 PDT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:-1296085792 1500 bytes is out-of-order; expected seq:2998782224. Reason: TCP reassembly queue overflow - session 10.48.25.172:50750 to 208.57.0.46:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
012373: .Sep 10 15:37:20.418 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012377: .Sep 10 15:38:50.562 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
012381: .Sep 10 15:39:56.759 PDT: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:-1507195997 1500 bytes is out-of-order; expected seq:2787703335. Reason: TCP reassembly queue overflow - session 10.48.25.137:56073 to 98.139.212.8:80 on zone-pair ccp-zp-in-out class ccp-protocol-http
012383: .Sep 10 15:40:20.647 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
I am having a separate VPN issues and the 230 address is the hub in a DMVPN configuration. So, i'm not surprised to see those log entries there (but I'm trying to seolve that as well).
can you ping 8.8.8.8  and modify this policy like this:
  pass
  inspect
  inspect
class class-default
  drop log
Have you got any log message this time?
Regards.
Alain
Good morning,
I've made the change and pinged 8.8.8.8 but still nothing relevant in the log:
013705: .Sep 11 08:53:09.818 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
013707: .Sep 11 08:54:39.894 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
013710: .Sep 11 08:55:39.974 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
013713: .Sep 11 08:57:10.123 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
013716: .Sep 11 08:58:10.203 PDT: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.230 has no SA and is not an initialization offer
I wonder if there is a problem with NAT and the VPN that is causing this issue?  Currently NAT is referencing access list 110:
But I probably don't want to NAT internal traffic that should go over the VPN. Would that affect the pings as well?
I was able to resolve this by removing this line from the config:
ip nat inside source static 10.48.25.1 zzz.zzz.zzz.26
I'm not sure why the router's WAN interface was NATed to the LAN interface. It doesn't seem to accomplish anything. I was able to ping from the router once I took that out.
Hi Kris,
Regards.
Alain
