WAN Interface mode Configuration
matthewlogan46
Which of the following configuration is the best or the recommended to connect two site?.
Topology:
SwitchLayer3GE0/1 -10.0.0.1---> ----> <----<--10.0.0.2-- GE0/1SwitchLayer3-02
Configuration Number 1-Interface Routing:
Switch Layer3-01
interface GE 0/1
no switchport
ip add 10.0.0.1 255.0.0.0
exit
Switch Layer3-02
interface GE 0/1
no switchport
ip add 10.0.0.2 255.0.0.0
exit
Configuration Number 2-Interface mode Trunk.
Switch Layer3-01
interface GE 0/1
switchport
switchport mode trunk
switchport trunk allowed vlan 10
exit
interface vlan 10
exit
Switch Layer3-02
interface GE 0/1
switchport
exit
interface vlan 10
exit
Jon Marshall
Matthew
Given the choice i would usually go with the routed interface setup because this means you do not run L2 protocols across the link, the key one being STP. With the trunk setup an STP problem in one site could have a knock on effect to the other site.
However if there is a requirement to have the same vlan in both sites ie. you need L2 adjacency for some devices split between the sites then you have to use the trunk option.
Jon
