Cannot ping secondary ip address
Praja9
Hi all.
I have a cisco 1921 router with the following interface configuration.
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.139.1.25 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.202.1.1 255.255.255.0 secondary
ip address 10.202.2.1 255.255.255.224 secondary
ip address 10.202.0.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/0/0
no ip address
shutdown
duplex auto
speed auto
I cannot ping PC 10.202.2.30 from the other subnet.
No access-lists set.
Is anything is missing here?
please help.
Thanks.
5 Replies 5
balaji.bandi
Questions to address the problem :
What is this device and how this is connected to network ?
interface GigabitEthernet0/1  - This port connected to Switch? if so what VLAN ?
we need to know your network topology what all the device involved between 10.202.2.30 to 10.202.2.1
BB
Hello
From the "other side" does the rtr have route(s) for those secondary prefixes?
sh ip route
sh arp
Kind Regards
Paul
Thank you for the prompt reply.
here are the outputs.
LVPS#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
10.0.0.0/8 is variably subnetted, 9 subnets, 4 masks
S 10.0.0.0/8 [1/0] via 10.139.1.12
C 10.139.1.0/24 is directly connected, GigabitEthernet0/0
L 10.139.1.25/32 is directly connected, GigabitEthernet0/0
C 10.202.0.0/24 is directly connected, GigabitEthernet0/1
L 10.202.0.1/32 is directly connected, GigabitEthernet0/1
C 10.202.1.0/24 is directly connected, GigabitEthernet0/1
L 10.202.1.1/32 is directly connected, GigabitEthernet0/1
C 10.202.2.0/27 is directly connected, GigabitEthernet0/1
L 10.202.2.1/32 is directly connected, GigabitEthernet0/1
LVPS#
LVPS#sh arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 10.202.2.1 - 00a2.eeaa.e2a1 ARPA GigabitEthernet0/1
Internet 10.202.2.2 0 0017.6110.ef46 ARPA GigabitEthernet0/1
Internet 10.202.2.3 0 0017.6110.efa1 ARPA GigabitEthernet0/1
Internet 10.202.2.4 191 0017.6110.f1a3 ARPA GigabitEthernet0/1
Internet 10.202.2.5 191 0017.6110.ef87 ARPA GigabitEthernet0/1
Internet 10.202.2.6 0 0017.6110.ef28 ARPA GigabitEthernet0/1
Internet 10.202.2.7 0 0017.6110.efc9 ARPA GigabitEthernet0/1
Internet 10.202.2.8 0 0017.6110.efdb ARPA GigabitEthernet0/1
Internet 10.202.2.9 0 0017.6110.f3ba ARPA GigabitEthernet0/1
Internet 10.202.2.10 0 0017.6110.ef56 ARPA GigabitEthernet0/1
Internet 10.202.2.11 0 0017.6111.2804 ARPA GigabitEthernet0/1
Internet 10.202.2.12 0 0017.6111.2807 ARPA GigabitEthernet0/1
Internet 10.202.2.13 201 0017.6110.ef39 ARPA GigabitEthernet0/1
Internet 10.202.2.15 137 0017.6110.eef2 ARPA GigabitEthernet0/1
Internet 10.202.2.16 33 0017.6110.f19d ARPA GigabitEthernet0/1
Internet 10.202.2.18 46 d067.e509.817d ARPA GigabitEthernet0/1
Internet 10.202.2.28 45 d067.e509.817d ARPA GigabitEthernet0/1
Internet 10.202.2.29 33 4439.c457.af7a ARPA GigabitEthernet0/1
Internet 10.202.2.30 3 4439.c457.af7a ARPA GigabitEthernet0/1
Hello
10.202.2.30 3 4439.c457.af7a ARPA GigabitEthernet0/1 <--reachable vai your gig0/1 interface
so where are you trying to connect to this ip from, what other subnet?
Does that other device have a route to 10.202.2.0/27
Kind Regards
Paul
I tried to ping it from a pc in 10.202.0.1/23 subnet, which is also connected on same interface.
Thanks.
