Cannot ping to other LAN in Packet Tracer - Please assist
Blackus
I am a networking student.
I was prompted by this page when I clicked on "ask a question" so I apologize if this actually isn't the right place to ask this. My problem is pretty simple and I think the solution will be simple too, but for whatever reason, I can't seem to figure it out on my own.
In the attached picture, you can see 3 routers in a triangle at the top, Toronto-Gateway, ISP, and Winnipeg-Gateway. My current problem is that I cannot ping the Toronto-Gateway interface g0/1 from the Winnipeg-Gateway. I have set up EIGRP, there aren't any ACLs in place, and I can ping the s0/0/0 interface, so I do not know why I cannot ping the g0/1 interface from Winnipeg-Gateway. PCs in the Toronto LAN cannot ping the Toronto-Gateway serial IP either, but they can ping everything within the LAN. I can post any other configurations you want but I believe the following are the only relevant ones.
Here are the configurations:
Toronto-gateway#sh run
Spoiler
Building configuration...
Current configuration : 1131 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Toronto-gateway
license udi pid CISCO1941/K9 sn FTX152405GG
spanning-tree mode pvst
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/1
ip address 172.16.0.14 255.255.255.252
duplex auto
speed auto
interface Serial0/0/0
description To Winnipeg
ip address 172.16.0.9 255.255.255.252
interface Serial0/0/1
description To ISP
ip address 172.16.0.1 255.255.255.252
interface Serial0/1/0
no ip address
shutdown
interface Serial0/1/1
no ip address
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 1
network 172.16.0.12 0.0.0.3
network 172.16.0.16 0.0.0.3
network 172.16.0.96 0.0.0.15
network 172.16.1.0 0.0.0.63
network 172.16.2.0 0.0.0.63
network 172.16.3.0 0.0.0.63
network 172.16.4.0 0.0.0.63
network 172.16.5.0 0.0.0.63
network 172.16.6.0 0.0.0.63
auto-summary
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Winnipeg-Gateway#sh run
Spoiler
Current configuration : 1166 bytes
version 15.1
hostname Winnipeg-Gateway
license udi pid CISCO1941/K9 sn FTX1524BXSX
no ip address
duplex auto
speed auto
shutdown
description to Winnipeg L3
ip address 172.16.0.17 255.255.255.252
duplex auto
speed auto
ip address 172.16.0.10 255.255.255.252
description To ISP
no ip address
shutdown
no ip address
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 1
auto-summary
ip classless
no cdp run
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
And as you can see, I can ping the s0/0/0 interface, but not g0/1 from Winnipeg-Gateway:
Spoiler
Winnipeg-Gateway#ping 172.16.0.9
Sending 5, 100-byte ICMP Echos to 172.16.0.9, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/3/8 ms
Winnipeg-Gateway#ping 172.16.0.14
Sending 5, 100-byte ICMP Echos to 172.16.0.14, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Any help is greatly appreciated. I believe the rest of the Toronto side LAN is fine as I have confirmed inter-vlan routing functionality. I just dont know why I can't ping anything from outside to the inside or vice versa of the Toronto LAN.
According to your lab, the following networks are missed in the EIGRP configuration.
Winnipeg-Gateway
router eigrp 1
network 172.16.0.8 0.0.0.3
Toronto-gateway
router eigrp 1
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
6 Replies 6
Deepak Kumar
I hope this is happening due to Auto Summary command. Make some changes in the EIGRP configuration on all routers.
router eigrp 1
no auto-summary
Also, attach your LAB so I can check all the details.
Deepak Kumar
Deepak Kumar,
Thanks for your reply
I added the no auto-summary command to both gateway routers but the problem still persists. This isn't a lab, but its a project I and some other students are working on, so there is no guide for this as far as I know. We designed the topology based on what we know. Maybe there is something similar, but I am not aware of that particular lab. Here is the file as requested. I hope you are still able to help, but if not, I understand.
EDIT: looks like .pkt files are not accepted here, so I cannot give you the file unless you would like me to upload it to a file sharing site.
Please add in the zip compression and add here.
Deepak Kumar
Deepak Kumar,
As requested. Thank you again for your time
Winnipeg-Gateway
router eigrp 1
Toronto-gateway
router eigrp 1
Deepak Kumar
Deepak Kumar,
This resolves the issue, thank you for your help.
