cannot remove command
leungcm
We have following router config. 192.168.10.25 is static NAT to one public IP address. we use "no" to remove it. However, it cannot remvoe. the command is still there and the "format"is changed. It becomes to:
ip nat inside source static 192.168.10.25 204.1.1.1 route-map <-- the nonat is missing
We cannot delete it. Any idea to delete this commands? please advise
interface GigabitEthernet0/0
ip address 204.1.1.30 255.255.255.0
ip nat outside
interface GigabitEthernet0/2
ip nat inside
ip nat inside source static 192.168.10.25 204.1.1.1 route-map nonat
route-map nonat permit 10
match ip address 100
access-list 100 deny ip 192.168.10.0 0.0.0.255 172.16.10.0 0.0.0.255
access-list 100 deny ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 100 permit ip 192.168.10.0 0.0.0.255 any
How are you trying to remove the NAT statement?
If the statement is in use then you need to remove the translation and then delete
Remove the ip nat inside or the ip nat outside command
Then remove the translations using clear ip nat transaltions and then try to remove the command
Narayan
