cannot specify multiple ports in mac-address-table static command
mhousley
Hello, i have a 6513 switch with a SUP720 supervisor module running v6.2.18 SXF11 and have a Microsoft NLB problem requiring a Static MAC address configuration to fix the problem..
I have tried to apply the command: -
mac-address-table static 02bf.0a30.011e vlan 20 interface gi12/11 gi12/12 po1
But the command errors at the "g" on the second interface definition.
Adding the command 3 times, each with a single interface doesn't work either, as each one overwrites the previous one.
i have done this in the past on other software versions and it has worked, but i cannot find out why this now doesn't work - am i doing something wrong?
5 Replies 5
mlund
Level 7
Level 7
I think it's because cisco doesn't support static unicast arp entry:s pointing to more than one port. Try with multicast mac-address instead.
Here are a good link that explains this.
http://www.internetworkpro.org/wiki/Configuring_Cisco_to_work_with_a_Windows_NLB_Cluster
/Mikael
ashirshov
Hi, you know how solve this proble?
I have too, and can't find any issue.
Help please.
Thank you.
It has been explained above, you cannot have same unicast mac on more than one port.
thank you.
You are welcome, please remember to rate useful posts with the scrollbox below.
