Error on C3600
cozyk1515
I have a C3600 that has no config on it. When I power it up I get
C3600 processor with 65536 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
loadprog: bad file magic number: 0x0
boot: cannot load "flash:"
System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
oC3600 processor with 65536 Kbytes of main memory
rommon 1 >
rommon 1 >
Can someone point me to a Document to figure this out?
Leo Laohoo
jiaowenbin
There are maybe serverl reasons cause your problem
1\ensure your flash disk (store ios) work well
2\ensure if boot command work well ,exmple :
rommon 1> dev ----list your what kind of media disks are in your router
rommon 2> dir flash: ------get your ios file name
rommon 3>boot c3660-xxx-xxx.bin
3\ if all above cannt boot your router,maybe flash disk has a hardware failure , change it
or , no ios file is in your flash disk,
if no ios file is in your flash disk ,
copy ios using tftp
copy ios using xmodem
copy ios using cf card adapter (u need to open the chassis ,find where flash disk locate)
send me e-mail for more help
leo.vpn@gmail.com ,CCIE Security & SP
