Cannot use RIPv2 with VLSM even with no auto-summary
aryspoty
Hello, I have an assignment where I have to route 3 routers that uses VLSM with RIPv2, ive assigned all the IPs needed to the pc and router, but I can't route with RIP
for example, when I try using RIP in router 2 and typed 198.66.66.160, it converted it to 198.66.66.0, so if I try adding another NA, for example 198.66.66.176, it wont add it.
I typing version 2 and
no auto-summary
to the router RIP CLI, but the same problem still occurs
Please check the file if I did anything wrong
turns out i actually got the connection in 'Router 2' switched, it is now fixed, thanks for the help
10 Replies 10
I can not open file but
show ip route
check the subnet for each interface is it match the
network
command mask or not ?
yes I've checked all 3 routers with
show ip route
  and all of the interface have the correct network address
Hello
show ip route
network
Wont be applicable in RIP by design
Kind Regards
Paul
@paul driver is right, I run small lab,
the route show classfull when I do show running
but in other router when I do
show ip route
 I see correct classless subnet.
so @paul driver is totally right.
thanks.
the subnet mask for 198.66.66.160 is 255.255.255.248
here is the screenshot of
show ip route
Hello
RIPv2 with auto summarization turned off VSLM is supported so classless advertisement of networks is allowed, meaning the correct VLSM subnet will be advertised in the network, however both RIP version1/2 will always default to its classful subnet (A,B,C)within it routing stanza, which cannot be changed, so what you see is correct.
Kind Regards
Paul
oh okay, but for some reason, its unable to ping to external network block, actually, only 2 network block are connected and the others aren't, you can see which one is connected with this image
Hello
Looks like you DONT have overlapping subnets but you need to make sure, plus all rtrs running rip will also need to be running RIP2 with auto summarization disabled.
/26
.0
.64
/27
.128
/29
.160
.168
.176
Kind Regards
Paul
check NA in all router, do you see it ?
