Is flash memory mandatory for ISR4331?
scut00
Hi everyone
I have a 4331 that was rescued from an upgrade process on a local datacenter, and they say it was working before removing it from production.
I now have a problem with it, not being able to boot it up no matter what I try.
It gives me the following log from the usb console:
Initializing hardware...
System integrity status: 00000610
Rom image verified correctly
System Bootstrap, Version 15.4(3r)S5, RELEASE SOFTWARE
Copyright (c) 1994-2015  by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: PowerCycleRequest
%ERROR: Critical device not found on 00:02.00
%WARNING: Resetting...
Power cycling .......
I tried to get into ROMMON, using all the tips and tricks that I could find online, and also checked the serial for the "clock component failure" with this units and mine is not affected.
So I was thinking, is the internal Flash Card mandatory? because the is none but the unit was still sealed.
Thank you for your help and your time.
8 Replies 8
balaji.bandi
Looks to me device failed - if you have contract you can ask RMA
So I was thinking, is the internal Flash Card mandatory?  - check what flash card you referring here install guide, if that was removed and it effects the device also.
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/hardware/installation/guide4400-4300/C4400_isr/FRUs_Modules.html#93750
BB
Yeah device failure is a possibility, but I can't get an RMA
The thing is I feel like it doesn't get the break command when I try to get into ROMMON, and I can't figure out what PCIe device is missing because it has a non-descriptive name
if you don't have contract to RMA
Open the Cover and check is all the Flash is in place as per the installation guide.
Personally, I believe the hardware failed.
BB
Leo Laohoo
IF the router is in ROMMON, post the complete output to the following command:
  1. dir flash:
  2. set
The flash, specifically eFlash, is soldered into the motherboard.  On top of the eFlash is an eFlash "slot" for expansion.
This could mean that someone may have tinkered with the config-registry so the router will boot immediately into ROMMON.
  1. dir flash:
  2. set
Hi, thanks for you reply.
Actually the biggest problem is that I cannot get into ROMMON, but just see it power cycle.
I tried multiple serial connection clients, multiple OS and wrote a kotlin script to spam the break command to the serial port, but with no success. If only I could get to ROMMON, I'm sure this would be more clear.
Do you have any tips on how to get into ROMMON? I think I'm doing something wrong or missing something
Depends on the console application and the console cable.
From putty it is possible to send a Break command during boot-up.
I tried putty, minicom, and also wrote a custom console in kotlin only to try and get it working. Is it possible that the cable I'm using does interfere with the sending of the break command while letting me see the console output? Because is a chep usb cable that I had, but if you think it can be the issue I can try buy a new one.
ISR 4k has a mini-USB console port.  Use that.
