cannot use the Windows Live Messager ( MSN )
andyskyview
Hi ALL Experts
i configured the 1841 router to connect with my ADSL service provide.
the problem cannot connect with MSN, other WEB service is OK
thanks
5 Replies 5
Danilo Dy
Did you check with your provider? They might be blocking it from their transparent proxy (intentionally or unintentionally)
Dandy
Hi Dandy
if i changed back to the home broadband router, the MSN service is ok
so i think the problem is in our 1841 config
thanks
Check this link http://ask-leo.com/how_do_i_resolve_my_msn_hotmail_sign_in_problems.html
It has multiple recommendation for people who are having problem connecting to MSN
Dandy
Hi dandy
first of all , thanks, but problem still persist
even if modify config according to the above link.
thanks
Hi Dandy
i found the solution for this case
in the dialer 1 interface
IP TCP adjust-mss 1452
thanks
