NTP version support for cisco routers and switches...
sarbudeen
I am planning to buy NTP server which is supporting version 2,3,4. is it possible to sync the time of switches and routers with this server. Need suggestion on this.
Rgds,
Sarbudeen
Edison Ortiz
IOS will support NTP server version number 1-3.
The default NTP version number is 3.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hcf_r/cfn_05h.htm#wp1047123
Edison Ortiz
Thanks you very much for the help
Sarbudeen
