04-06-2008 03:02 AM - edited 03-03-2019 09:26 PM
Hi, I'm ready to give up on this :)
I have a Cisco 877w DSL router. I can access the Internet fine via ethernet, but I have tried to configure wireless on the router but can't connect to it. When I browse the wireless networks I can see it (ssid MyN3t), but when I try connect to it I don't get prompted for the WPA password.
My ISO is the latest c870-advipservicesk9-mz.124-15.T4
Config attached, I hope you can help!
04-11-2008 09:05 AM
Please go through this Cisco 800 Series Routers Troubleshoot and Alerts
04-11-2008 11:32 AM
Actually, from what I've found, configuring those is a bit trickier than regular routers. Unfortunately because of the way our Proxy serves are configured, I can't see attachments, so I don't know what your config is... However, the basics are quite simple if you think about it...
What you want is for your wireless and your wired connections to be in the same subnet. Normally put the IP address on the Ethernet interface of a router for the LAN. But then how does the wireless get on the same subnet? VLAN's? This router does have a VLAN interface for putting the IP on for its shared ethernet ports, but AP's use "BVI" interfaces and that's the key... "BVI" is Bridge Virtual Interface.
Set up a "BVI 1" interface and put your LAN IP address on that instead of the VLAN interface.
interface BVI1
description $ES_LAN$
ip address 10.X.X.X AAA.BBB.CCC.DDD
no ip route-cache
Then, put your Do0 interface and VLAN 1 interface on bridge-group 1
interface Dot11Radio0
no ip address
bridge-group 1
bridge-group 1 spanning-disabled
interface Vlan1
no ip address
no ip route-cache
bridge-group 1
And you should be all set. If your wired network works, your wireless should, that is assuming you have your WPA set up right... We're using this with EAP-FAST, so I can't help you with that part!!
