Default route in GSR
hassan_syed6
I am searching cisco website and also Google, but any of you know how to get bgp restrictive routing defined on Cisco GSR (so the customer gets ONLY a default route instead of the full routing table) in BGP
paolo bevilacqua
Hi, the bgp configuration is identical to all other cisco routers so you use filters etc to send only the route you want.
