Cant get PAT to work in Cisco Packet Tracer
fullaccess
Title says it all. I'm a complete newbie to cisco packet tracer, I started using it 2 days ago so I'm quite lost. Anyway my network (
.pkt file
attached) is as follows:
The ISP server with
ip 208.67.220.220
acts as both a dhcp and a dns server. The router's WAN interface
(gig0/0/0)
gets its ip from the ISP server with dhcp and the LAN interface's
(gig0/0/1) ip is 192.168.0.1
which belongs to VLAN 1. There are other 2 vlans: VLAN 10 with PC0, PC1 and the L3 switch with
ip 192.168.1.1
and VLAN 20 with PC2, PC3 and the L3 switch with
ip 192.168.2.1
The L3 switch is also on vlan 1 with
ip 192.168.0.2, and its default gateway
is the router's lan interface
(192.168.0.1)
The L3 switch is also a VTP server and the L2 switches are its clients. I've enabled ip routing in the L3 switch and I also added a static route in the router which routes all traffic from
192.168.0.0/16 to 192.168.0.2
(the L3 switch). From the pcs I can ping pcs in other vlans as well as the router. With this setup I want to ping the ISP server from one of the pcs, in order to do this I configured PAT in the router. The router is configured like this:
Router#show running-config
Building configuration...
Current configuration : 852 bytes
version 15.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip cef
no ipv6 cef
spanning-tree mode pvst
interface GigabitEthernet0/0/0
ip address dhcp
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/0/1
ip address 192.168.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/0/2
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router rip
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip classless
ip route 192.168.0.0 255.255.0.0 192.168.0.2
ip flow-export version 9
access-list 1 permit 192.168.0.0 0.0.255.255
line con 0
line aux 0
line vty 0 4
login
end
I'm completely lost as to why it doesnt work.
I think that all is ok but you’re missing a
default route
to the outside from your router.
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
BR
Diogo
ammahend
Your routing between L3 switch and Router is not in place, your PAT config was right, once routing is Fixed, I can see translation, seee the fixed file attached.
-hope this helps-
Martin L
I added
default route to L3 switch; your ip default-gateway 192.168.0.1
is not for L3 switches but for just L2 ones;
Add ip route 0.0.0.0 0.0.0.0 192.168.0.1
Ping Pcs to server and I got
Router#sh ip nat translations
Pro Inside global Inside local Outside local Outside global
icmp 208.67.220.2:1 192.168.1.2:1 208.67.220.220:1 208.67.220.220:1
icmp 208.67.220.2:9 192.168.1.3:9 208.67.220.220:9 208.67.220.220:9
Regards, ML
**Please Rate All Helpful Responses **
default route
BR
Diogo
