Cant ping other pc
Stonez263
so i have one router and 2 switches and 2 pcs.
the 2 pcs have ip address of 192.168.20.10 and the other one 192.168.10.10
from 20.10 i can ping 10.10
but i cant ping 20.10, i can only ping its gateway
how can i solve this?
Pawan Raut
Level 4
Level 4
Do you have any acl on vlan
We need some clarification from the original poster. He says that he can not ping 20.10 and I assume that the ping is from 10.10. Is he able to ping 20.10 from the router?
A very common problem that produces these symptoms is that the host 20.10 may be running a firewall which permits outbound ping but denies ping to the host. If ping from the router to 20.10 fails then it is likely that we have a firewall issue.
Rick
Rick
