Cant ping PT-Server
Al3xX995
Hello everyone.
I've made this project in packet tracer, but i cant ping the 2 servers and i cant find out what's wrong. Can you help me? Here is a screenshot of the project and the steps i've done:
“Router0”:
g0/0  10.10.10.1/24
g0/1  10.10.11.1/24
s0/3/0200.1.1.1/30
“Router ISP”:
g0/08.0.0.1/8
g0/1 11.0.0.1/8
s0/3/0200.1.1.2/30
- PC0  10.10.11.10/24
- PC1  10.10.11.20/24
- PC2  10.10.11.30/24
- PC3  10.10.10.10/24
- PC4  10.10.10.20/24
- Server “google”  8.8.8.8/8
- Server “facebook”11.11.11.11/8
“Router0”:
Router; enable
Router# conf t
Router(config)# hostname Router0
Router0(config)# interface g0/0
Router0(config-if)# ip address 10.10.10.1 255.255.255.0
Router0(config-if)# no shut
Router0(config-if)# interface g0/1
Router0(config-if)# ip address 10.10.11.1 255.255.255.0
Router0(config-if)# interface Serial0/3/0
Router0(config-if)# ip address 200.1.1.1 255.255.255.252
Router0(config-if)#end
“RouterISP”:
Router; enable
Router# conf t
Router(config)# hostname RouterISP
RouterISP(config)# interface g0/0
RouterISP(config-if)# ip address 8.0.0.1 255.0.0.0
RouterISP(config-if)# no shut
RouterISP(config-if)# interface g0/1
RouterISP(config-if)# ip address 11.0.0.1 255.0.0.0
RouterISP(config-if)# interface Serial0/3/0
RouterISP(config-if)# ip address 200.1.1.2 255.255.255.252
RouterISP(config-if)#end
Default route router 0
Router0; enable
Router0# conf t
Router0(config)# ip route 0.0.0.0 0.0.0.0 s0/3/0
Router0(config)# end
RouterISP Static route
RouterISP; enable
RouterISP# conf t
RouterISP(config)# ip route 10.10.10.0 255.255.255.0 s0/3/0
RouterISP(config)# ip route 10.10.11.0 255.255.255.0 s0/3/0
RouterISP(config)# end
The gateway in your end devices must be the ip address of the router.
Your actual configuration: The gateway for 10.10.10.0 is 10.10.10.25, gateway for 10.10.11.0 is 10.10.11.25
Change for: The gateway for  10.10.10.0 is 10.10.10.1, gateway for 10.10.11.0 is 10.10.11.1
Jaderson Pessoa
*** Rate All Helpful Responses ***
10 Replies 10
Jaderson Pessoa
Does yours end devices, has gateway configured properly?
Jaderson Pessoa
the 2 servers has a default gateway too
post the Packet Tracer project (.pkt) file, ZIP it first otherwise you cannot upload...
Dear Al3xX995,
Configure on yours devices, like server, pc.. default gateway for them. There is no gateway configured in your devices on pt file.
Jaderson Pessoa
in the project file you sent, none of the devices including the servers has a default gateway configured at all. I have added the gateways, and each PC can now ping both servers.
Jaderson Pessoa
Thank you so much, i had some doubts on the default gateway configuration, now i finally understand how to configure it. Thanks to all the users who replied!
good lucky in your studies.
Please, mark as helpful and solved all pots that help you.
Thanks in advance.
Jaderson Pessoa
luis_cordova
Hi @Al3xX995,
Could you compress the pkt file and share it to be able to revise it?
