Regex for BGP 32Bit Private AS Range
neilobrien
Hi All,
Similar to the regex /(6451[2-9]|645[2-9][0-9]|64[6-9][0-9][0-9]|65[0-4][0-9][0-9]|655[0-2][0-9]|6553[0-5])/ for 16bit Private AS 64512-65535, I'm looking for a regex that will cover the 32bit Private AS Range 4200000000 - 4294967294.
Unfortunately, /[4200000000-4294967294]/ won't work in my case, I could use /42[0-9][0-9][0-9][0-9][0-9][0-9][0-9][0-9]/ but I think that casts the net too far.
I've been looking around and can't find anything suitable.
Thanks in advance,
Neil
rais
Level 7
Level 7
The last expression seems the one to work. It can't cast the network too far as 4294967294 is the limit.
HTH.
