Cant telnet to router via ATM interface side
Jacob-Harris
Deployed a new 3825 to this office w/ ATM.
Since moving to ATM have not been able to telnet to the router through the ATM Interface (Tried ip of atm, eth, and loopback no success). Can telnet to a switch behind the router and then telnet to the router from the switch.
Switch <--> ATM Router <--> T3 Router <--> Client trying to connect to ATM Router.
ATM Router ATM Config
interface ATM0/IMA1
mac-address 0015.629a.f100
ip address 10.216.117.1 255.255.255.0
ip route-cache flow
atm vc-per-vp 1024
atm uni-version 3.0
no atm auto-configuration
no atm ilmi-keepalive
no atm address-registration
no atm ilmi-enable
pvc 1/777
protocol ip 10.216.117.2 broadcast
vbr-nrt 3000 3000 1
oam-pvc manage
encapsulation aal5snap
interface ATM0/0/0
no ip address
no scrambling-payload
ima-group 1
no atm oversubscribe
atm uni-version 3.0
no atm ilmi-enable
interface ATM0/0/1
no ip address
ima-group 1
atm uni-version 3.0
no atm ilmi-enable
ATM Router gig interface
interface GigabitEthernet0/0
description Lancaster router to switch connection
ip address 172.16.0.1 255.255.255.0 secondary
ip address 10.231.16.1 255.255.254.0
ip helper-address 10.231.16.20
no ip unreachables
duplex auto
speed auto
media-type rj45
negotiation auto
Richard Burts
Jacob
There are several things that might produce the symptoms that you describe and we do not yet have enough information to identify the most likely cause.
One potential problem is not having a working route to the telnet target, or the telnet target not having a return route to the client. One way to test this would be to ping the address of the telnet target from the client. If ping works then it is not an IP connectivity problem. The fact that you can telnet to the switch behind the router suggests that it is not an IP connectivity problem. ping would confirm this.
When you attempt to telnet what happens? Do you get a prompt to login? Do you get an error message and if so what is the error message? Knowing these things would help narrow down the cause of the problem.
Another thing that might cause these problems is an access list. Is there any access list on any interface? There did not seem to be any in the config that you posted but it was not the complete config. There might also be an access list on the vty ports (assigned with access-class) which controls telnet access. Is there any access-class on the vty ports?
Rick
Rick
Can ping Router ethernet interface from host:
H:\>ping 10.231.16.1
Pinging 10.231.16.1 with 32 bytes of data:
Reply from 10.231.16.1: bytes=32 time=148ms TTL=248
Reply from 10.231.16.1: bytes=32 time=52ms TTL=248
Can ping from router also to host.
Sending 5, 100-byte ICMP Echos to 10.221.40.139, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 76/111/148 ms
No access-list defined on any of the interfaces.
VTY Configed as follows
line vty 0 4
password 7 ****************
login
length 25
transport input all
Pretty stumped on this one, seems weve tried everything.
