Cat6800 to new c9800 WLC via PO71
williamsonjason
Hi all, Im having trouble getting my cores to route to my new WLC...
I cannot ping the core from the WLC, and cannot ping the wlc from the core.
Cores to WLC: 2 interfaces, members of PO71. VLAN allowed statement in use (allowed vlan 271)
WLC to Cores: 2 interfaces, members of PO3. VLAN allowed statement in use (allowed vlan 271 (tried ALL, as well)
"Show cdp nei" on the WLC shows me that the core interfaces are connected & cdp is working.
WLC mgmt IP is 10.3.2.11 (cannot ping from core)
Core Int vlan 271 IP is 10.3.2.2 (pings from the core & my laptop)
network statement exists:
router ospf 103
router-id 10.x.x.x (removed for security)
network 10.3.2.0 0.0.0.31 area 0
coreswitch#show ip arp | inc 10.3.2.
Internet 10.3.2.2 - 0008.e3ff.fc28 ARPA Vlan271 (the int vlan 271 IP)
Internet 10.3.2.11 0 Incomplete ARPA (supposed to be my wlc - but why is it imcomplete?)
17 Replies 17
Share etherchannel summary
I need to check health of PO you use.
MHM
williamsonjason
Group Port-channel Protocol Ports
3 Po3(SU) - Te0/1/0(P) Te0/1/1(P)
williamsonjason
etherchannel seems to be working ok
It mode is ON so I need to check wlc 9800 and PO mode ON.
I will update you
MHM
Can you share show etherchannel summary from both sides and share spanning tree on SW side.
MHM
williamsonjason
"mode on" on both sides (since this is a cisco-to-cisco connection"
williamsonjason
(core side)
show etherchannel summary:
71 Po71(SU) - Te1/1/30(P) Te1/5/30(P)
Show spanning tree
Show interface status
In Core SW
MHM
williamsonjason
Core Switch
Show spanning-tree
Po71 Desg FWD 1 128.5789 P2p
Core switch:
show interface status
Po71 C9800-WLC10-DES connected trunk a-full a-10G
Te1/1/30 PO71-C9800-WLC10-D connected trunk full 10G 10Gbase-SR
Te1/5/30 PO71-C9800-WLC10-D connected trunk full 10G 10Gbase-SR
In Core
Show ip interface breif
Show interface trunk
Check vlan SVI is up/up
Check if vlan allow in trunk PO.
MHM
williamsonjason
SVI int 271 is up/up
vlan allowed is in trunk PO
show wireless interface summary
check if mgmt interface is up/up
MHM
Leo Laohoo
Passive Interface?
Leo, are you talking about an ospf.passive statement or something else?
