Show ip ospf interface brief on packet tracer.
Fabián Perilla
Hello everyone!
I am using a topology from Wendell Odom's book:
my question is that I am using that topology to simulate the network on packet tracer, but when I issue the command
SHOW IP OSPF INTERFACE BRIEF
to see the neighbor count, it displays 0/0, already knowing that the neighbor adjacency was successfully completed:
Above the picture showing 0/0
As you see the neighbor count is completed according to SPF logic if I issue the command
show ip ospf interface x
per interface. But I also have the
last version of PT 8.2.0
I really appreciate if you could give me a hand to solve this problem or understanding why packet tracer doesn't show it. Thanks in advance!
Joseph W. Doherty
Answer is quite simple, PT is a simulator teaching tool, it's not an 100% full emulator or real device.
I.e. many "real" IOS features are not implemented or only implemented partially.
Joseph W. Doherty
balaji.bandi
Not really understand the issue.
Do you like t see the neighbors, you need to use
show ip ospf neigh
BB
rcargnel
The following command "show ip ospf int Gig0/0" shows the neighbor count as well as the adjacent neighbor count "Neighbor Count is 3, Adjacent neighbor count is 2".
R1-end>show ip ospf int Gig0/0
GigabitEthernet0/0 is up, line protocol is up
Internet address is 10.1.1.1/24, Area 0
Process ID 1, Router ID 1.1.1.1, Network Type BROADCAST, Cost: 1
Transmit Delay is 1 sec, State DROTHER, Priority 1
Designated Router (ID) 4.4.4.4, Interface address 10.1.1.4
Backup Designated Router (ID) 3.3.3.3, Interface address 10.1.1.3
Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
Hello due in 00:00:06
Index 1/1, flood queue length 0
Next 0x0(0)/0x0(0)
Last flood scan length is 1, maximum is 1
Last flood scan time is 0 msec, maximum is 0 msec
Adjacent with neighbor 4.4.4.4 (Designated Router)
Adjacent with neighbor 3.3.3.3 (Backup Designated Router)
Suppress hello for 0 neighbor(s)
