Catalyst 6500 L2 over IPSEc
Idan Grinshpon
Is catalyst 6500 supports L2TPv3 over IPSEC in combination with  VPN Services Port Adapter (VSPA) ?
Is catalyst 6500 supports VPLS over IPSEC in combination with  VPN Services Port Adapter (VSPA) ?
6 Replies 6
Edison Ortiz
1) No, 6500 only supports EoMPLS
2) Yes, but you need a SIP400 or SIP600 GigaSpa in addition to the VPN SPA which does IPSEC
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/configuration/6500series/76cfgeth.html#wpmkr1147084
Edison.
Can you describe the traffic flow, please? When IPSEC encapsulation of GRE tunnel performed & how "GRE encapsulated traffic" redirected to VSPA  from SIP-400/600??
The VPN SPA will take care of any IPSec related services hence removing this load from the CPU or any other ASIC on the switch.
The SIP400 with a GigaSPA will take care of the physical traffic leaving the switch.
I highly suggest you become familiar with the hardware and configuration so please read the documentation:
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/install_upgrade/6500series/sipspahw.html
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/configuration/6500series/sipspasw.html
Where encapsulation of MPLS traffic to GRE tunnel performed? On VSPA or GigaSpa ?
If the answer "On VSPA" - so the output of VSPA is regular IP packet (non MPLS) so why I need GigaSpa WAN card, can't i use LAN card (like 6748) ???
Or you mean that the MPLS packet encapsulated in GRE tunnel on GigaSpa and then IPSEC encapsulated on VSPA ??
MPLS is performed on the GigaSPA.
You can use a regular line card as the one you mentioned but it won't support VPLS
And before you ask, EoMPLS over GRE is not supported on 6500.
 Idan Grinshpon
 System Engineer
 Defense Division
 8 Hanehoshet St
 Tel-aviv , 69710, Israel
 Tel:03-6459032
 Mobile:052-5529032
 Fax:03-5480651
 idang@bynet.co.il
