Catalyst 9500-32C-A EVPN/VXLAN scale numbers
Aaron D
Trying to understand the scale matrix I found below. We are wanting to use EVPN as an L2 replacement. Currently we use VPLS on our 6880's. Our concern is related to the Bridge-Domain limits listed below. Is it true we can only have 225 VLAN's in use on one set of 9k's if using EVPN?
We have far more that 225 VLANs in use, and this seems immensely low compared to the potential for 16M VLANs with VXLAN.
I tried mapping multiple instances for a MST-like scenario, but no joy. Any input is appreciated.
Using 17.5.1 on 9k.
LAB-RTR-41(config-vlan-config)#vlan configuration 649
LAB-RTR-41(config-vlan-config)# member evpn-instance 1 vni 4101
% EVPN instance with vlan-based service type can only be attached to one VLAN
0 Replies 0
