CATOS to IOS Layer-3 Etherchannel
phil_carter
I am trying to configure a Layer-3 etherchannel between a 6500 running CATOS (with MSFC Layer-3 card) and a 6500 IOS device.
IOS:
interface Port-channel2
description G7/1 & G7/2 Ether to HAVC6501 7/1 & 7/2
no switchport
ip address 10.5.3.177 255.255.255.252
interface GigabitEthernet7/1
description <cct ID> HAVC6501 G7/1 to Corporate Core
no switchport
channel-group 2 mode active
interface GigabitEthernet7/2
description <cct ID> HAVC6501 G7/2 to Corporate Core
no switchport
CATOS:
set channelprotocol lacp 7
set vlan 403 7/1-2
set port lacp-channel 7/1-2 mode active
MSFC (IOS):
int vlan 403
Description /30_VLAN_to_HAVAGG_X650_01C_Po2
ip address 10.5.3.178 255.255.255.252
It works fine when its just a Layer-2 etherchannel at each end, but I can't get the Layer-3 working. Can anyone advise what is wrong, or how this should be configured?
Phil
Jon Marshall
Phil
There is nothing wrong as such but unfortunately CatOS only supports L2 etherchanneling and not L3 so a switch in hybrid mode is limited to L2 etherchannels only.
Jon
I was hoping that wasn't the answer!.... I suppose the below may work instead?
6500 IOS
G7/1
descr To CATOS_6500_7/1
no sw
ip address 10.0.0.1 255.255.255.252
ip load-sharing per-packet
G7/2
descr To CATOS_6500_7/2
no sw
ip address 10.1.0.1 255.255.255.252
6500 CATOS:
set vlan 403 7/1
set vlan 404 7/2
6500 MSFC:
interface vlan 403
descr To Ports_7/1
ip addres 10.0.0.2 255.255.255.252
interface vlan 404
descr To Ports_7/2
ip address 10.1.0.2 255.255.255.252
Phil
