CBWFQ for diff Customers
Just Kennie
Hi all,
I am trying to assign bandwidth for two different clients using CBWFQ, I use a class map to call the address of each clients defined by an access-list.
MY OBJECTIVE IS TO ASSIGN 128KBPS FOR EACH CUSTOMER WITH LEAST CONFIG BECAUSE OF RESOURSES!
WHAT IS THE EFFECT OF EACH CONFIG, AND WHICH SERVE THE PURPOSE  ?
....................................... A.................................
ip access-list standard CUSTOMER1
permit 10.0.0.1
ip access-list standard CUSTOMER2
permit 10.0.0.2
class-map match-any 128KBPS
match access-group name CUSTOMER1
match access-group name CUSTOMER2
policy-map CUSTOMERS
class 128KBPS
  bandwidth 128
........................B.............................
permit 10.0.0.1
permit 10.0.0.2
class 128KBPS
  bandwidth 128
....................................C..................................
permit 10.0.0.1
permit 10.0.0.2
class-map match-any CUSTOMER1
class-map match-any CUSTOMER2
class CUSTOMER1
  bandwidth 128
class CUSTOMER2
  bandwidth 128
Jon Marshall
You need to use C because the other 2 only assign 128Kbps between both customers ie. they will share the 128Kbps between them. C allocates 128Kbps to each customer.
Jon
