Showing results forĀ
Search instead forĀ
Did you mean:Ā
CCIE R& S and CCNP troubleshooting
I)I am Plan to write CCNP trouble shooting and CCIE R&S.
2)I need to guidance for the same.. How exam will look like is similar to CCNA, CCNP Route & SWITCH.
Above 3 exams at Point 2 have 3 labs, 47 question including multiple choice & drag and drop  all are objective..
is above mention at Point 1 is similar or  how it will be differ. Trouble shoot i heared there will  8 Lab Question includes 4 Objective of each lab 32 Question will be covered and somemultiple choice and drag and drop. But dont have any idea about CCIE R & S.
any site for prepration  will  be helpful as well..
InayathUlla Sharieff
CCNP TS you are correct.
I just finish my CCIE written exam.There would be no Lab scenario, Just questions and 1-2 drag and drop.
Note one thing that once you answer the question you cannot go back to the prev question.
Inayath
In CCIE R&S written exam there is no lab like CCNP exam...
Vignesh Rajendran Praveen
Hi Dinesh,
The CCIE R&S stream has two exams. The first is the CCIE R&S witten exam which the qualifier for the CCIE R&S Lab exam. The written exam has around 50 to 60 multiple choice questions. Once you pass this exam you are eligible to appear for the CCIE R&S Lab exam.
In CCIE R&S Lab exam you have two parts.
1) Troubleshooting Part - Duration for this is 2 hours within which you need to troubleshoot 10 trouble tickets.
2) Configuration Part - Duration given for this is 6 hours within which you need to build & configure the lab from                                  scratch to finish based on the exercises given under different sections.
You can also refer to the below link for more clarity.
http://www.cisco.com/web/learning/certifications/expert/ccie_rs/index.html
Refering to forums under certcollection.org would also help.
***********Plz do rate this post if you found it helpful*************************
Thanks & Regards,
Vignesh R P
Hi Dinesh,
Yes you are right in CCIE R&S written exam there is no lab like CCNP exam.
Thanks & Regards,
Vignesh R P
