CCNP Lab
lexdtran1975
I'm looking for CCNP lab and i don't know what to buy.
Thanks in advance
ropethic
Level 4
Level 4
Check Ebay, they have a lot of good labs.
There are also simulators out there as well that run on your PC. I actually purchased from http://networksims.com/. Pretty good
http://ciscogeek.org/cisco-simulator/
chull6509
I started out filling my home lab with buying a setup of three 2950 switches, two 3640 routers, and a 2610XM router. All were tested, latest IOS, and clean. Since then I have purchased some more gear for a lot less money. No face plates, not the latest IOS, dusty and with scratches. I don't care how it looks, just that it works. Look hard and you can get what you need for around $1,000.
Thanks for your respond!
Check out GNS3. You can build bigger, more complex networks for free.
http://www.gns3.net/
Hope this helps, rate if it does.
JB
