cdt: %FW-4-TCP_OoO_SEG: Dropping TCP Segment:
Adnan Khan
Level 4
Level 4
Jun 14 23:43:29 cdt: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:3837741645 1500 bytes is out-of-order; expected seq:3837627765. Reason: TCP reassembly queue overflow - session x.x.x.x:63150 to y.y.y.y:80
What could be cause this log message keep generating on router 2951 model and configured DMVPN tunnels.
2 Accepted Solutions
Giuseppe Larosa
Hello @Adnan Khan ,
it is acting as a Hub in DMVPN ? or it is a Spoke ?
With standard public internet services over Ethernet with L3 MTU 1500 bytes  the IPSEC and GRE overhead causes the devices specially the hub to face the issue of the need to reassembly IP packets containing a TCP segment ( L4 PDU).
if you are in this scenario you need to know the ISR has limited resources to store TCP segments waiting to be re-assembled.
the message says that the device is not able to handle a big flow that is moving a large file.
Hope to help
Giuseppe
*DMVPN with IPSec,
try increase the IPSec anti-reply window size
the window can make some packet drop and hence tcp segment is out-of-order
https://www.cisco.com/c/en/us/td/docs/routers/asr920/configuration/guide/sec_vpn/sec-ipsec-xe-3s-book-920/configuring_ipsec_anti_replay_window_expanding_and_disabling.pdf
or try increase the Queue of tcp reassembly
ip inspect tcp reassembly queue length 128
ip inspect tcp reassembly timeout 10
Mark Elsen
 - Probably a similar bug report : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCti71232  , meaning check current software version on the router , use an advisory release (upgrade) , if applicable ,              check if that can help.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Giuseppe Larosa
Hello @Adnan Khan ,
Hope to help
Giuseppe
balaji.bandi
what IOS Code running, how is your config ? do you have zone based Firewall config ?
BB
*DMVPN with IPSec,
