CE router that keeps trying to be a DCE
dewaldt05
below is the interface config and output from serial interface. for some reason it keeps on trying to be a dce when if my understanding is correct, it should be a dte, receving its clocking from the NTE. anything anyone can think of that might be causing this?
show controllers s0/1/0
Interface Serial0/1/0
Hardware is SCC
DCE V.11 (X.21), clock rate 2000000
show run int s0/1/0
Building configuration...
Current configuration : 242 bytes
interface Serial0/1/0
description ** VPNN900720  CSAC323173  ICUK709873  MXIP239706  **
bandwidth 2048
no ip address
ip flow ingress
encapsulation frame-relay IETF
no ip route-cache
clock rate 2000000
frame-relay lmi-type ansi
end
Current configuration : 163 bytes
interface Serial0/1/0.1 point-to-point
bandwidth 2048
ip unnumbered Loopback1
ip flow ingress
no ip route-cache
frame-relay interface-dlci 101 IETF
end
dewaldt05
seems the nte was faulty. eventually had bt come swap it after arguing with them for hours.
