CEF over Serial
PLC
Hello All, I set up 3 routers with serial connections. When I ping I was getting success rate is 40 percent 2/5. After i disabled no ip cef i got 100 percent success on all routers.
I cant think of specific reason why this worked and should be disabled. Can anyone tell me why?
Thanks for your help!
R2#sho ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES unset  administratively down down
Serial1/0                  unassigned      YES unset  administratively down down
Serial1/1                  unassigned      YES unset  administratively down down
Serial1/2                  unassigned      YES unset  administratively down down
Serial1/3                  unassigned      YES unset  administratively down down
R2#config t
Enter configuration commands, one per line.  End with CNTL/Z.
R2(config)#int serial 1/0
R2(config-if)#ip address 192.168.1.2 255.255.255.0
R2(config-if)#no shut
R2(config-if)#^Z
R2#
*Jun 19 11:31:27.955: %LINK-3-UPDOWN: Interface Serial1/0, changed state to up
*Jun 19 11:31:27.955: %ENTITY_ALARM-6-INFO: CLEAR INFO Se1/0 Physical Port Administrative State Down
R2#
*Jun 19 11:31:28.715: %SYS-5-CONFIG_I: Configured from console by console
*Jun 19 11:31:28.959: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to up
R2#ping 192.168.1.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Success rate is 80 percent (4/5), round-trip min/avg/max = 748/1370/1844 ms
R2#wr mem
Building configuration...
[OK]
R2#sho run int s1/1
Current configuration : 76 bytes
interface Serial1/1
 no ip address
 shutdown
 serial restart-delay 0
end
R2#config t
R2(config)#int serial1/1
R2(config-if)#ip address 192.168.1.6 255.255.255.0
R2(config-if)#^Z
R2#
*Jun 19 11:48:45.035: %LINK-3-UPDOWN: Interface Serial1/1, changed state to up
*Jun 19 11:48:45.035: %ENTITY_ALARM-6-INFO: CLEAR INFO Se1/1 Physical Port Administrative State Down
R2#
*Jun 19 11:48:45.487: %SYS-5-CONFIG_I: Configured from console by console
*Jun 19 11:48:46.039: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/1, changed state to up
R2#ping 192.168.1.5
Sending 5, 100-byte ICMP Echos to 192.168.1.5, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 244/1505/1968 ms
R2#sh run int serial1/0
Current configuration : 89 bytes
interface Serial1/0
end
R2#sh run int serial1/1
interface Serial1/1
end
R2#ping 192.168.1.1
Success rate is 0 percent (0/5)
R2#ping 192.168.1.5
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/196/892 ms
R2#sho run
Current configuration : 1146 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
no ip icmp rate-limit unreachable
ip tcp synwait-time 5
ip cef
no ip domain lookup
no ip dhcp use vrf connected
no ip ips deny-action ips-interface
interface FastEthernet0/0
 no ip address
 shutdown
 duplex half
interface Serial1/0
interface Serial1/1
interface Serial1/2
 no ip address
 shutdown
interface Serial1/3
 no ip address
 shutdown
ip classless
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
gatekeeper
 shutdown
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line vty 0 4
 login
end
R2#  sh int
FastEthernet0/0 is administratively down, line protocol is down
  Hardware is DEC21140, address is ca02.5769.0000 (bia ca02.5769.0000)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Half-duplex, 100Mb/s, 100BaseTX/FX
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     0 packets output, 0 bytes, 0 underruns
     1 lost carrier, 0 no carrier
Serial1/0 is up, line protocol is up
  Hardware is M4T
  Internet address is 192.168.1.2/24
  MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
  Encapsulation HDLC, crc 16, loopback not set
  Restart-Delay is 0 secs
  Last input 00:00:10, output 00:00:05, output hang never
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1158 kilobits/sec
     172 packets input, 12050 bytes, 0 no buffer
     Received 152 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     177 packets output, 12929 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     2 carrier transitions     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
Serial1/1 is up, line protocol is up
  Hardware is M4T
  Internet address is 192.168.1.6/24
  Last input 00:00:00, output 00:00:04, output hang never
     51 packets input, 4372 bytes, 0 no buffer
     Received 42 broadcasts, 0 runts, 0 giants, 0 throttles
     60 packets output, 5277 bytes, 0 underruns
Serial1/2 is administratively down, line protocol is down
  Hardware is M4T
     Conversations  0/0/256 (active/max active/max total)
     0 packets input, 0 bytes, 0 no buffer
     1 carrier transitions     DCD=down  DSR=down  DTR=up  RTS=up  CTS=down
Serial1/3 is administratively down, line protocol is down
  Hardware is M4T
R2#  ping 192.168.1.2
Sending 5, 100-byte ICMP Echos to 192.168.1.2, timeout is 2 seconds:
R2#ping 192.168.1.5
R2#ping 192.168.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/548/1048 ms
R2#ping 192.168.1.2
R2#ping 192.168.1.5
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/177/796 ms
R2#ping 192.168.1.5
Success rate is 60 percent (3/5), round-trip min/avg/max = 20/146/384 ms
R2#ping 192.168.1.1
R2#ping 192.168.1.1
R2#ping 192.168.1.1
R2#ping 192.168.1.1
R2#sho run
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip domain lookup
 no ip address
 shutdown
 duplex half
interface Serial1/0
interface Serial1/1
interface Serial1/2
 no ip address
 shutdown
interface Serial1/3
 no ip address
 shutdown
ip classless
no ip http server
control-plane
gatekeeper
 shutdown
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line vty 0 4
 login
end
R2#config t
R2(config)#no ip cef
R2(config)#^Z
R2#config t
*Jun 19 12:16:58.631: %SYS-5-CONFIG_I: Configured from console by console
R2#ping 192.168.1.1
Success rate is 60 percent (3/5), round-trip min/avg/max = 28/30/32 ms
R2#ping 192.168.1.1
Success rate is 40 percent (2/5), round-trip min/avg/max = 28/56/84 ms
R2#ping 192.168.1.1
Success rate is 60 percent (3/5), round-trip min/avg/max = 32/212/556 ms
R2#ping 192.168.1.1
Success rate is 40 percent (2/5), round-trip min/avg/max = 40/42/44 ms
R2#ping 192.168.1.1
Success rate is 80 percent (4/5), round-trip min/avg/max = 48/73/128 ms
R2#ping 192.168.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/232/1044 ms
R2#ping 192.168.1.1
Success rate is 80 percent (4/5), round-trip min/avg/max = 44/528/1140 ms
R2#ping 192.168.1.5
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/198/888 ms
R2#sho run
Current configuration : 1149 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
no ip cef
no ip domain lookup
 no ip address
 shutdown
 duplex half
interface Serial1/0
interface Serial1/1
interface Serial1/2
 no ip address
 shutdown
interface Serial1/3
 no ip address
 shutdown
ip classless
no ip http server
control-plane
gatekeeper
 shutdown
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line vty 0 4
 login
end
R2#ping 192.168.1.5
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/291/1328 ms
R2#ping 192.168.1.1
Success rate is 60 percent (3/5), round-trip min/avg/max = 12/198/544 ms
R2#ping 192.168.1.1
Success rate is 60 percent (3/5), round-trip min/avg/max = 20/146/388 ms
R2#ping 192.168.1.1
Success rate is 40 percent (2/5), round-trip min/avg/max = 20/32/44 ms
R2#ping 192.168.1.1
Success rate is 60 percent (3/5), round-trip min/avg/max = 20/190/508 ms
R2#
R2#
R2#
R2#
R2#sho run
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
no ip cef
R2#ping 192.168.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/409/1048 ms
R2#ping 192.168.1.5
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/199/852 ms
R2#ping 192.168.1.5
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/144/616 ms
R2#
7 Replies 7
Peter Paluch
This is strange. There is no reason for a well-behaved CEF implementation to cause packet losses like the ones you have experienced in your network.
Based on the types of interfaces and IOS versions you're using, am I correct in assuming you are running this topology on a GNS3/Dynagen/Dynamips simulator? If so, I suggest upgrading that in the first place.
Also, does this behavior persist when you try a different IOS version?
Best regards,
Peter
Thanks for chiming in Peter! Yes, I got this going on GNS3 dynamips simulation. I havent tried on a different ios. I will try upgrading gns3... see what that does.
ok, I upgraded my gns3 to the latest and greatest and i tried a different iOS and it behaved the same.
as soon as i introduce a third router thats when it starts dropping packets until i disable no ip cef. Weird.. once i do that pings are success 5/5
Can you post a snapshot of your GNS3 window so that the topology is more clear? Also, what exact IOS are you running?
Best regards,
Peter
 Software (C7200-JK9O3S-M), Version 12.4(1a), RELEASE SOFTWARE (fc2)- I orginally used the above iOS
(C3620-J1S3-M), Version 12.3(13), RELEASE SOFTWARE (fc2)- I tried this the second time after I upgraded the gns 3.
I attached a screen shot. pretty simple /24 on each interface all interfaces are in the up and up state.
I've noticed a glitch in your configuration: On R2, both serial interfaces are in the same IP network 192.168.1.0 (your netmask is /24 on both interfaces). In general, this is an invalid configuration, as two routed interfaces cannot be in the same IP subnet. For some reason long unknown to me, routers allow you to configure multiple serial interfaces for the same IP subnet even though it does not make much sense.
In any case, if R2 believes it has two routes into the same network - which it apparently believes right now - it is allowed to do load-balancing, and this may actually be the reason why your pings have been intermittently lost.
Try reconfiguring your topology so that the R1/R2 subnet is unique and different from R2/R3 subnet, say:
R1/R2: 192.168.12.0/24, R1 = .1, R2 = .2
R2/R3: 192.168.23.0/24, R2 = .2, R3 = .3
The reason why deactivating CEF might have had an influence on the success of the pings is probably more complex. Packets originated by a router alone are always process-switched and are not subject to CEF. However, if, for a particular pinged destination, R2 arbitrarily chose the source IP and the egress interface, it may have happened that the ping went just to the opposite router than the one it was destined to. The opposite router would have routed the packet back (the logic of serial interfaces is that every IP address in the serial interface's network is located on the other end), and now, because this packet was received back, it was no longer locally originated but rather a received packet eligible for routing, so CEF applies to it. By default, CEF performs per-destination load balancing, hashing the source and destination IP and performing a path choice. As I mentioned, the original packet had its source IP address arbitrarily chosen, depending on the original egress interface. It is quite possible that for a specific combination of the source and destination IP, R2 gets the packet back and decides to forward the packet received from the other router back to the same other router, essentially creating a routing loop. That would explain the lost packets. Without CEF, the next forwarding method would be the route cache and finally process switching. I am not sure at this moment what the behavior would be with the route cache. However, with process switching, packets would eventually make it because process switching performs a per-packet load balancing, so the packet would possibly make multiple turns before making it out the correct interface.
In any case, you configuration needs to be corrected - after doing that, I believe that the packet losses will no longer occur.
Best regards,
Peter
Doh! thank you Paul. That was the issue... all is pinging now that i put them in different subnets lol... I usually put a /30 not sure why I put /24.
