CEF Unsupported features?
mdeanhall
I have an issue that looks to be cef related.
Design is essentially a private L2 cloud to multiple customers. Head end router then creates an encrypted tunnel via a virtual template, and vrf lite.
Design runs smooth on a 3945 but with about 10 meg sustained I noticed about 30% cpu utilization for the ip input process alone.
After doing some checking I believe it is all related to packets being process switched instead of CEF due to unsupported features.
I'm trying to deterine if that is the case, and if so, what the unsupported feature may be so I can fix the design.
some relevent information -
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.0(1)M4, REL
System image file is "flash0:c3900-universalk9-mz.SPA.150-1.M4.bin"
"sh cef drop" -
IPv4 CEF Drop Statistics
Slot  Encap_fail  Unresolved Unsupported    No_route      No_adj  ChkSum_Err
RP             0           0  2798289680          99           0           0
*** Interface Template and an associated virtual access interface
interface Virtual-Template1 type tunnel
ip vrf forwarding BLUE
ip unnumbered Loopback1
ip access-group vrf_traffic_filter_2 in
load-interval 30
tunnel source Loopback0
tunnel mode ipsec ipv4
tunnel protection ipsec profile P1
service-policy output mpls-shape
end
interface Virtual-Access3
load-interval 30
tunnel destination 172.16.3.49
no tunnel protection ipsec initiate
end
MPLS-HE#sh int Virtual-Access3
Virtual-Access3 is up, line protocol is up
  Hardware is Virtual Access interface
  Interface is unnumbered. Using address of Loopback1 (172.16.2.1)
  MTU 17888 bytes, BW 100000 Kbit/sec, DLY 50000 usec,
  Encapsulation TUNNEL
  CDMA vaccess, cloned from Virtual-Template1
  Vaccess status 0x4, loopback not set
  Keepalive not set
  Tunnel source 192.168.22.201 (Loopback0), destination 172.16.3.49
   Tunnel Subblocks:
      src-track:
         Virtual-Access3 source tracking subblock associated with Loopback0
          Set of tunnels with source Loopback0, 27 members (includes iterators), on interface <OK>
  Tunnel protocol/transport IPSEC/IP
  Tunnel TTL 255
  Tunnel transport MTU 1448 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Tunnel protection via IPSec (profile "P1")
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 2w1d
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  30 second input rate 25000 bits/sec, 60 packets/sec
  30 second output rate 222000 bits/sec, 61 packets/sec
     30488660 packets input, 2061222615 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     29446885 packets output, 11700198786 bytes, 0 underruns
     0 unknown protocol drops
MPLS-HE#
MPLS-HE#sh cef int virtual-access 3
Virtual-Access3 is up (if_number 19)
  Corresponding hwidb fast_if_number 19
  Corresponding hwidb firstsw->if_number 19
  Internet address is 0.0.0.0/0
  Unnumbered interface. Using address of Loopback1 (172.16.2.1)
  ICMP redirects are never sent
  Per packet load-sharing is disabled
  IP unicast RPF check is disabled
  Input features: Access List
  Output features: CCE Post NAT Classification, AF Policing, Post-Ingress-NetFlow
  Post encapsulation features: IPSEC Post-encap output classification
  IP policy routing is disabled
  BGP based policy accounting on input is disabled
  BGP based policy accounting on output is disabled
  Interface is marked as point to point interface
  Interface is marked as tunnel interface
  Hardware idb is Virtual-Access3
  Fast switching type 14, interface type 21
  IP CEF switching enabled
  IP CEF switching turbo vector
  IP Null turbo vector
  VPN Forwarding table "BLUE"
  IP prefix lookup IPv4 mtrie 8-8-8-8 optimized
  Input fast flags 0x21, Output fast flags 0x4008
  ifindex 22(22)
  Slot  Slot unit 3 VC -1
  IP MTU 1448
  Real output interface is GigabitEthernet0/1
MPLS-HE#
Truncated cef information from the vrf :
MPLS-HE#sh ip cef vrf BLUE
Prefix               Next Hop             Interface
10.160.49.0/24       172.16.2.49          Virtual-Access3
172.16.2.49/32       172.16.2.49          Virtual-Access3
192.168.1.128/25     10.95.0.1            GigabitEthernet0/0
                              10.95.0.9            GigabitEthernet0/2
192.168.1.240/28     10.95.0.1            GigabitEthernet0/0
172.16.2.1/32        receive              Loopback1
192.168.190.0/24     10.95.0.1            GigabitEthernet0/0
MPLS-HE#
I have the design running in a test lab (2900 instead of 3900) so I can test.
So far, I have tested by removing the tunnel, and placing all interfaces into the same vrf. In that case the cef unsupported drops no longer increments.
Can anyone provide and ideas what I should look at, and/or a link to unsupported features in cef?
skarthic
Can you check "show ip cef switching statistics feature" output too? I am hoping it would give some info on why the packets are punted. If this is a test setup try "debug ip cef drops".
From the production device:
MPLS-HE#sh ip cef switching statistics feature
IPv4 CEF input features:
       Feature                Drop    Consume       Punt  Punt2Host Gave route
       Access List               0          0          0 24323291709          0
Total                            0          0          0 24323291709          0
IPv4 CEF output features:
       Feature                Drop    Consume       Punt  Punt2Host    New i/f
       AF Policing               7          0          0          0          0
Total                            7          0          0          0          0
IPv4 CEF post-encap features:
       IPSEC Post-encap         73 24233024017          0          0          0
Total                           73 24233024017          0          0          0
IPv4 CEF for us features:
Total                            0          0          0          0          0
IPv4 CEF punt features:
Total                            0          0          0          0          0
IPv4 CEF local features:
Total                            0          0          0          0          0
MPLS-HE#
So an access list is causing the punts??
Based on what I've read cef works off the ingress interface, and there are no access lists on either of the inside interfaces (example below)
interface GigabitEthernet0/0
description to Core
ip address x.x.x.x x.x.x.x
ip flow ingress
duplex auto
speed auto
The only thing that does have an ACL is the virtual-template (limiting inbound traffic to be sourced from 10.160.0.0/16)
Based on the above I'll think I'll try ripping the ACL off in test lab to see the result.
I'll also do the debug cef drops in lab when I get a chance.
I am wondering if ACL would be the issue here. I guess it could be your VPN traffic getting punted or something. Not sure if your vpn configuration is supported in CEF. But as per your plan, do continue your tests and let us know the results.
