Cellular Modem has been power cycled : NP
Joris Schoot
We have several C1117-4PLTEEA routers. With firmware:
Cisco IOS XE Software, Version 16.09.02
Cisco IOS Software [Fuji], ISR Software (ARMV8EB_LINUX_IOSD-UNIVERSALK9_IAS-M), Version 16.9.2, RELEASE SOFTWARE (fc4)
Some of them work perfectly and some of them have a issue with the LTE after a couple of weeks. They show the following logging:
018039: Jul 5 06:56:30.196: %CELLWAN-2-LINK_RECOVERY: Cellular0/2/0: Cellular Modem has been power cycled : NP
018040: Jul 5 06:56:30.203: %IOSXE-3-PLATFORM: R0/0: ngiolite: CWAN:FD close request from IOS
018041: Jul 5 06:56:35.205: %IOSXE-3-PLATFORM: R0/0: ngiolite: update_modem_ctrl : MODEM_CTRL_MSG_RESET:
018042: Jul 5 06:56:38.330: %IOSXE-3-PLATFORM: R0/0: ngiolite: SWI modem Action:[remove] State[2]
018043: Jul 5 06:56:59.195: %CELLWAN-2-MODEM_DOWN: Modem in slot 0/2 is DOWN
018044: Jul 5 06:57:22.610: %IOSXE-3-PLATFORM: R0/0: ngiolite: SWI modem Action:[add] State[1]
018045: Jul 5 06:59:32.331: %CELLWAN-2-MODEM_UP: Modem in slot 0/2 is now UP
018046: Jul 5 06:59:32.532: %CELLWAN-2-MODEM_RADIO: Cellular0/2/0 Modem radio has been turned on
After the modem has turned on the interface does not change to UP and no data is transported. Even though the modem is active. After a couple of minutes of being in this state the modem get cycled again and the whole thing repeats..
My questions are:
What can cause this?
And what is power cycle reason: NP
Anyone knows how to fix this?
Best regards,
Joris
5 Replies 5
what if you manually reload the hardware module, does the problem persist after doing that ?
hw-module subslot 0/2 reload
Hello Georg,
After a hardware reload or a test cell modem-power-cycle, the modem functions fine for a short time and then the problem recurres again.
So unfortunately it did not help.
Best regards,
Joris
Hi Joris,
did you solved the problem ?
Best regards.
Hello Janis,
No I still have issues with some 1100 series routers.
Best regards
kvaitt
Hello folks,
Any luck with the solution? I encountered similar problem during the configuration and since then the cellural0/2/0 never come up with an IP address. SIM card is working and correct, it just seem as modem stopped working. any ideas?
Router#
*Apr 24 22:26:19: %CELLWAN-2-LINK_RECOVERY: Cellular0/2/0: Cellular Modem has been power cycled : NP
*Apr 24 22:26:19: %IOSXE-3-PLATFORM: R0/0: ngiolite: CWAN:FD close request from IOS
Router#
*Apr 24 22:26:21: %SYS-2-PRIVCFG_ENCRYPT: Successfully encrypted private config file
Router#
Router#
Router#
Router#
Router#
*Apr 24 22:26:24: %IOSXE-3-PLATFORM: R0/0: ngiolite: update_modem_ctrl : MODEM_CTRL_MSG_RESET:
Router#
*Apr 24 22:26:37: %IOSXE-3-PLATFORM: R0/0: ngiolite: WWAN modem Action:[remove] State[2]
Router#
*Apr 24 22:26:48: %CELLWAN-2-MODEM_DOWN: Modem in slot 0/2 is DOWN
Router#
*Apr 24 22:27:10: %IOSXE-3-PLATFORM: R0/0: ngiolite: WWAN modem Action:[add] State[1]
Router#
